Ir para o conteúdo principal
How to Repair a Cracked Mirror
Marriam Shaikh
Marriam Shaikh e um outro colaborador
Última atualização em December 18, 2023
2 horas
Fácil
This iFixit guide will show you how to repair a cracked mirror using items that can easily be found in a windshield repair kit, or purchased separately from any store.
In this guide, you will use epoxy resin adhesive to fill in and cure the crack in the mirror. This simple procedure can be done at home and does not require any prerequisite skills. This will allow you to preserve your mirror, rather than throwing it out and contributing to more waste in the environment.
Do use caution when handling the razor blade, and wear gloves if needed, to protect your hands.
  1. How to Repair a Cracked Mirror, How to Repair a Cracked Mirror: passo 1, imagem 1 %32
    • Clean the mirror with soap and water.
  2. How to Repair a Cracked Mirror: passo 2, imagem 1 %32 How to Repair a Cracked Mirror: passo 2, imagem 2 %32 How to Repair a Cracked Mirror: passo 2, imagem 3 %32
    • Remove the adhesive backing of the stabilizer film.
    • Press the stabilizer film over the crack.
    • Use your fingers to smooth out the stabilizer film.
  3. How to Repair a Cracked Mirror: passo 3, imagem 1 %32
    • Fill the syringe with epoxy resin.
  4. How to Repair a Cracked Mirror: passo 4, imagem 1 %32 How to Repair a Cracked Mirror: passo 4, imagem 2 %32
    • Insert the tip of the syringe through the stabilizer film.
    • Push down the plunger to fill the crack with resin.
  5. How to Repair a Cracked Mirror: passo 5, imagem 1 %32
    • Set a timer for 20 mins and wait for the resin to harden.
  6. How to Repair a Cracked Mirror: passo 6, imagem 1 %32
    • Peel off the stabilizer film.
  7. How to Repair a Cracked Mirror: passo 7, imagem 1 %32 How to Repair a Cracked Mirror: passo 7, imagem 2 %32
    • Add a drop of resin over the crack.
    • Cover the resin with the curing film.
  8. How to Repair a Cracked Mirror: passo 8, imagem 1 %32
    • Set a timer for 1 hour and wait for the resin to cure.
  9. How to Repair a Cracked Mirror: passo 9, imagem 1 %32 How to Repair a Cracked Mirror: passo 9, imagem 2 %32
    • Remove the curing film.
    • Scrape away any excess resin using the razor blade.
    • Use caution when handling the razor blade as you do not want to cut yourself during the process.
  10. How to Repair a Cracked Mirror: passo 10, imagem 1 %32
    • Clean the area with glass cleaner.
Conclusão
Marriam Shaikh
Membro desde: 09/18/23
181 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 61
Últimos 30 dias: 252
Duração total: 3,338
