Ir para o conteúdo principal
How to Repair a Broken Drawstring Tunnel in a Backpack
Ben Blischke
Ben Blischke e um outro colaborador
Última atualização em 11 de abr de 2025
15 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
If your backpack's drawstring is loose and the closing mechanism isn't working as it should, don't worry! We've got you covered. In just a few simple steps, we'll show you how to repair the string and make your favourite backpack as secure and comfortable as it used to be!
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
O que você precisa
Ferramentas
Exibir mais…
  1. How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: passo 1, imagem 1 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: passo 1, imagem 2 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: passo 1, imagem 3 %32
    • Identify the defective area and assess how large the damage is.
  2. How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: passo 2, imagem 1 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: passo 2, imagem 2 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: passo 2, imagem 3 %32
    • Cut away any damaged threads around the drawstring tunnel, to create a clean surface to repair.
  3. How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: passo 3, imagem 1 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: passo 3, imagem 2 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: passo 3, imagem 3 %32
    • Place the drawstring inside the tunnel.
    • Turn the edges inside, so that the drawstring is tucked inside.
  4. How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: passo 4, imagem 1 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: passo 4, imagem 2 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: passo 4, imagem 3 %32
    • Pin the folded parts of the tunnel securely in place and prepare the sewing machine.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Depress the sewing machine foot and remove any pins in the way of the sewing route.
  5. How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: passo 5, imagem 1 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: passo 5, imagem 2 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: passo 5, imagem 3 %32
    • Start sewing a straight line from one side to the other and add a lock stitch at the beginning and the end.
    • Finish the sewing and cut the loose thread to make a neat finish.
  6. How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: passo 6, imagem 1 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: passo 6, imagem 2 %32 How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: passo 6, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Gear Up For Future Repairs
Shop all
Ben Blischke
Membro desde: 07/19/23
9.900 Reputação
Autoria de 66 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
24 Membros
Autoria de 166 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 283
