Ir para o conteúdo principal
How to Repair Scratches in Laminate Finish Furniture
Shelby
Shelby e um outro colaborador
Última atualização em May 28, 2024
3 horas
Fácil
This guide will show you how to repair any scratches that might appear on your laminate finish furniture. This method can be used for both shallow and deep scratches and involves using a wood filler product to repair damage. Wood filler comes in a variety of colors so pick one that best matches your furniture, or color match with paint.
This guide will help you improve the appearance of your furniture and extend the use of the piece.
  1. How to Repair Scratches in Laminate Finish Furniture, How to Repair Scratches in Laminate Finish Furniture: passo 1, imagem 1 %32
    • Clean the scratched area with a damp cloth or paper towel to remove any dust or debris.
  2. How to Repair Scratches in Laminate Finish Furniture: passo 2, imagem 1 %32
    • Apply a small amount of wood filler to a putty knife.
    • The amount of wood filler needed may vary depending on severity of the scratches.
  3. How to Repair Scratches in Laminate Finish Furniture: passo 3, imagem 1 %32
    • Spread the wood filler over the scratches using the putty knife until they are sufficiently filled in.
    • The putty knife can be used to scrape away excess wood filler and smooth the surface.
  4. How to Repair Scratches in Laminate Finish Furniture: passo 4, imagem 1 %32
    • Wipe away any residual wood filler from the surface using a damp cloth or paper towel.
  5. How to Repair Scratches in Laminate Finish Furniture: passo 5, imagem 1 %32
    • Allow the wood filler to dry completely based on the package instructions before resuming use.
  6. How to Repair Scratches in Laminate Finish Furniture: passo 6, imagem 1 %32
    • Sand over the wood filler using fine-grit sandpaper if a smoother finish is desired.
  7. How to Repair Scratches in Laminate Finish Furniture: passo 7, imagem 1 %32
    • Paint over the wood filler, if desired, to color match the filler with the furniture.
    • Wood filler comes in a variety of colors so painting may not be necessary.
Linha de Chegada
Shelby
Membro desde: 02/20/24
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 52
Duração total: 346
