Ir para o conteúdo principal
How to Repaint Your Garage Floor
Chao Zheng
Chao Zheng e 5 outros colaboradores
Última atualização em December 22, 2021
30 minutos - 4 horas
Moderado
Introdução
Ir para o passo 1
This is an easy guide is for people who are and are not well-versed with tools. The aim is to teach people how to refurbish their garage floors after it being weathered by cars, footprints, or other items. This skill can also be applied to similar painting jobs, such as fence painting.
There are many purpose for repainting your garage floor from just wanting to add another color to the floor to wanting to give your garage a cleaner, more well put together look. No matter the reason this guide will help you through the step by step process of repainting your garage floor.
NO pre-requisite skill needed. Some tools are required as listed below. Ensure floor is clean to make sure paint stays.
  1. How to Repaint Your Garage Floor, How to Repaint Your Garage Floor: passo 1, imagem 1 %32
    • Use a paint scraper to remove the old paint from the area where you want to apply the new paint.
    • It's okay if there is still some old paint left on the surface.
    • Paint cracks usually indicate corrosion and require scraping.
  2. How to Repaint Your Garage Floor: passo 2, imagem 1 %32
    • Remove debris and dust with a broom.
  3. How to Repaint Your Garage Floor: passo 3, imagem 1 %32
    • Examine the quality of your paint.
    • If it is too thick, and you're using water-based paint, mix in a little bit of water.
    • If it is too thick, and you're using an oil-based paint, add paint thinner.
  4. How to Repaint Your Garage Floor: passo 4, imagem 1 %32
    • Wet the surface of the roller with water.
  5. How to Repaint Your Garage Floor: passo 5, imagem 1 %32 How to Repaint Your Garage Floor: passo 5, imagem 2 %32
    • Pour the paint in a container, dip your roller in, and start rolling.
    • You can also use a paint brush.
  6. How to Repaint Your Garage Floor: passo 6, imagem 1 %32
    • New paint has been applied and you can see the direct contrast.
    • When the paint has dried, reapply a second coat of paint.
  7. How to Repaint Your Garage Floor: passo 7, imagem 1 %32
    • Collect all the tools and prepare them for cleaning.
    • For water-based paint, rinse the tools in water. For oil-based paint, rinse the tools in paint thinner.
    • When rinsing, don't dip your tools in your paint thinner container directly. Instead, pour the paint thinner into another container that can be used for rinsing the tools.
Conclusão
Follow these instructions so you can be the next person to learn how to paint.
Uma outra pessoa concluiu este guia.
Chao Zheng
Membro desde: 09/20/20
177 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 28
Ao todo: 892
