How to Remove scratches from a CD
Introdução
Ir para o passo 1This guide is for anyone who has a scratched CD that is not working any more. In most cases this relatively quick and easy method has worked for me, and hopefully it works for you too.
O que você precisa
Ferramentas
Let the CD sit for 2 to 3 minutes.
Unless I’m missing something, If you’re using toothpaste to polish the scratches out of a CD, there’s no need to let it sit with the paste on it. It’s the circular motion moving the aggregate in the paste that is removing the scratches.
Ik ben het hiermee eens. Wat zou het nut zijn om de tandpasta een tijdje op de CD te laten rusten?
44 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all5Comentários do guia
Works great!
thank youuuuuuuuu
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
It did not work for me
Me Funciono muy bien, gracias!
