Ir para o conteúdo principal
How to Remove scratches from a CD
Nick Jones
Nick Jones e 3 outros colaboradores
Última atualização em 29 de ago de 2024
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
This guide is for anyone who has a scratched CD that is not working any more. In most cases this relatively quick and easy method has worked for me, and hopefully it works for you too.
O que você precisa
Ferramentas
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: passo 1, imagem 1 %32
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
  2. How to Remove scratches from a CD: passo 2, imagem 1 %32 How to Remove scratches from a CD: passo 2, imagem 2 %32
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
  3. How to Remove scratches from a CD: passo 3, imagem 1 %32
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
  4. How to Remove scratches from a CD: passo 4, imagem 1 %32 How to Remove scratches from a CD: passo 4, imagem 2 %32 How to Remove scratches from a CD: passo 4, imagem 3 %32
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
  5. How to Remove scratches from a CD: passo 5, imagem 1 %32
    • Let the CD sit for 2 to 3 minutes.
    Unless I’m missing something, If you’re using toothpaste to polish the scratches out of a CD, there’s no need to let it sit with the paste on it. It’s the circular motion moving the aggregate in the paste that is removing the scratches.
    Jimmy Hoffa - Responder
    Ik ben het hiermee eens. Wat zou het nut zijn om de tandpasta een tijdje op de CD te laten rusten?
    Roy Damman - Responder
  6. How to Remove scratches from a CD: passo 6, imagem 1 %32
    • Rinse off the toothpaste with lukewarm water.
  7. How to Remove scratches from a CD: passo 7, imagem 1 %32
    • Let the CD air dry, or dry with a non-linen towel.
  8. How to Remove scratches from a CD: passo 8, imagem 1 %32
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
Conclusão
44 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Nick Jones
Membro desde: 09/29/15
1.485 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-4, Green Fall 2015 Membro de Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 Membros
Autoria de 17 guias
5Comentários do guia
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - Responder
It did not work for me
Leisy Madrigal - Responder
Me Funciono muy bien, gracias!
Esteban Montero - Responder
Comentar
Visualizações:
Últimas 24 horas: 55
Últimos 7 dias: 394
Últimos 30 dias: 1,677
Ao todo: 74,866
