How to Remove Underwires from a Bra
Introdução
Ir para o passo 1Do you have an underwired bra that doesn’t fit quite right? Or, a broken underwire that is poking you? In either case, follow this guide to remove the underwire from your bra and continue using your favorite bra for several more years.
This guide will help to remove the underwires which will prevent you from feeling any more discomfort. In the end, you will still have a bra it will feel brand new again!
Removing the underwires is not difficult. It is a quick fix and the skill can be applied to other similar fixes needed for apparel. A seam ripper is ideal to quickly safely and neatly extract the underwires from your bra, but this project can be accomplished with any similar alternative tool that is sleek and sharp.
O que você precisa
Peças
Ferramentas
Exibir mais…
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
