Ir para o conteúdo principal
How to Remove Screen Google Nest Hub
Jason Nairn
Jason Nairn e 2 outros colaboradores
Última atualização em September 15, 2021
40 minutos
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
Basic how to showing where the glue is and how to get the unit open
O que você precisa
Peças
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. How to Remove Screen Google Nest Hub, Breaking Glue Connection: passo 1, imagem 1 %32
    • The unit has no retaining clips on the top or bottom but the top where the camera eye is located is the easiest to get a pry tool into. A heat gun is recommended to soften the glue but I found I didn't need it to get the glass off (but my thumb may never be the same again)
    • avoiding going in directly where the camera is your only looking to go a few MM in as the glass is glued on and its just the thickness of the glass top and bottom.
    • Working your way round you should find two studs at each side at around the same level as the glass top and bottom.
  2. How to Remove Screen Google Nest Hub, Remove Screen Ribbon: passo 2, imagem 1 %32 How to Remove Screen Google Nest Hub, Remove Screen Ribbon: passo 2, imagem 2 %32
    • Once you get the glass off take care to not rip the ribbon. picture one is the ribbon locked in the closed position (no ribbon shown but the input to the slot is marked with the triangle and the number 1 bottom left )
    • Red arrow shows where to lift the locking arm the blue arrow shows the ribbon insertion direction
  3. How to Remove Screen Google Nest Hub, Clean Screen Area: passo 3, imagem 1 %32
    • Clean up the excess glue around the edges and wait for your new screen to arrive.
Conclusão
7 outras pessoas executaram este guia.
Jason Nairn
Membro desde: 12/10/20
298 Reputação
Autoria de 1 guia
6Comentários do guia
What width is the tape you used?
Dan Bradnam - Responder
what tape? the new screen had glue round it just popped it back in ( only just noticed now they have added a video! that isn't me)
Jason Nairn -
"on how do I replace orange cable
Kim Quintero - Responder
You would need to strip the top bracket off but not sure where you would get a new ribbon cable
Jason Nairn -
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 27
Últimos 30 dias: 115
Ao todo: 14,346
