Ir para o conteúdo principal
How to Remove Rust from a Gardening Shovel
Brigette B
Brigette B e um outro colaborador
Última atualização em December 15, 2023
30 minutos - 2 dias
Fácil
The purpose of this guide is to show the process of how to remove the rust off of a gardening shovel.
When a metal shovel is left outside in the elements for too long, it has the potential to become rusted over. When this happens, you are able to remove this rust at home using household items.
Though this is a simple process that can be done at home, it can be lengthy and require a moderate amount of effort to physically remove the rust depending on the level of tarnish.
  1. How to Remove Rust from a Gardening Shovel, How to Remove Rust from a Gardening Shovel: passo 1, imagem 1 %32
    • Fill a large container with water.
  2. How to Remove Rust from a Gardening Shovel: passo 2, imagem 1 %32
    • Add an ample amount of distilled white vinegar.
  3. How to Remove Rust from a Gardening Shovel: passo 3, imagem 1 %32
    • Soak the shovel for at least 10 minutes, but ideally for 24 hours.
  4. How to Remove Rust from a Gardening Shovel: passo 4, imagem 1 %32
    • Scrub the shovel with a scrub brush.
    • Scrub with a tooth brush.
    • Scrub with a Brillo pad.
  5. How to Remove Rust from a Gardening Shovel: passo 5, imagem 1 %32
    • Refill the large container with fresh water.
  6. How to Remove Rust from a Gardening Shovel: passo 6, imagem 1 %32
    • Add 1-2 cups of baking soda.
  7. How to Remove Rust from a Gardening Shovel: passo 7, imagem 1 %32
    • Soak the shovel for 15 minutes.
  8. How to Remove Rust from a Gardening Shovel: passo 8, imagem 1 %32
    • Rinse the shovel.
  9. How to Remove Rust from a Gardening Shovel: passo 9, imagem 1 %32
    • Dry the shovel completely.
  10. How to Remove Rust from a Gardening Shovel: passo 10, imagem 1 %32
    • Oil the shovel with coconut oil.
Conclusão
Repeat process until rust is completely removed.
Brigette B
Membro desde: 09/22/23
181 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 169
