Ir para o conteúdo principal
How to Remove Odor From Shoes
Jerome Amegbeto
Jerome Amegbeto e 2 outros colaboradores
Última atualização em July 28, 2024
4 - 8 horas
Fácil
Introdução
Ir para o passo 1
What do you do when your favorite shoes start to smell? Do you just spray the insides with Febreze and call it good? What do you do when a week goes by and your shoes start to smell again? If you can't afford to get your shoes cleaned every time they start to stink, here's an easy, cost-effective way to get the smell out. Whether you're a college student, an athlete, or just someone active in their daily life, here's a six-step, simple process to get the odor out of your favorite pair of shoes.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Remove Odor From Shoes, How to Remove Odor From Shoes: passo 1, imagem 1 %32
    • Lift the shoe's tongue up so you can see the inside of the shoe.
  2. How to Remove Odor From Shoes: passo 2, imagem 1 %32 How to Remove Odor From Shoes: passo 2, imagem 2 %32 How to Remove Odor From Shoes: passo 2, imagem 3 %32
    • Place two dryer sheets in each shoe: one in the far front where the toes are and another in the back where the visible sole is.
    • Dryer sheets help the shoe smell nice and will keep the baking soda from getting in your shoes.
  3. How to Remove Odor From Shoes: passo 3, imagem 1 %32 How to Remove Odor From Shoes: passo 3, imagem 2 %32 How to Remove Odor From Shoes: passo 3, imagem 3 %32
    • Pour a handful of baking soda on the dryer sheet covering the visible sole of each shoe.
    • Baking soda can make a mess so do be careful when pouring some into the shoe.
  4. How to Remove Odor From Shoes: passo 4, imagem 1 %32
    • Leave the dryer sheets and baking soda in your shoes for 4-8 hours.
    • If you are in a hurry, one hour is enough to notice a difference with odor removal.
  5. How to Remove Odor From Shoes: passo 5, imagem 1 %32
    • Remove the baking soda and dryer sheets after 4-8 hours.
    • Use disinfectant wipes to clean any excess baking soda left in each shoe.
  6. How to Remove Odor From Shoes: passo 6, imagem 1 %32
    • Run the shoes in a washing machine on a cold cycle for a final touch.
Linha de Chegada
Jerome Amegbeto
Membro desde: 09/16/21
182 Reputação
Autoria de 1 guia
Equipe
3Comentários do guia
Why are deodorizing insoles the best to control shoe odor?
Deodorizing insoles are considered to be the best odor remover because they provide a targeted solution to the problem of foot odor. By being placed directly in the shoe, they come into contact with the source of the odor, the foot, and work to neutralize the bacteria that cause the smell. Unlike other odor removers, such as sprays or powders, insoles do not just mask the odor, they actively work to eliminate it.
One of the best brands of deodorizing insoles is Aginsole. They use a unique combination of silver ion technology and special elastomers to provide maximum odor-fighting power. Silver ions have been shown to be effective in neutralizing bacteria and fungi, making them a powerful tool in the fight against foot odor. The special elastomers used in Aginsole insoles provide a comfortable and durable fit, ensuring that they will last for a long time.
https://www.agreentech.com/
Mike Tao - Responder
I always prefer to read quality and glad I found this thing in your post. Thank you for the comprehensive article. if you need a discount promo code for branded shoes
Lucas Henry - Responder
I've tried everything to get rid of the smell from my shoes, but nothing worked until I came across this post. The tips are practical and easy to follow, and I'm happy to say that my shoes no longer smell bad. Thanks for sharing! yimusanfendi
dot cinker - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 3,119
