Ir para o conteúdo principal
How to Remove Cutting Board Scratches
Preethi Thomas
Preethi Thomas e um outro colaborador
Última atualização em August 8, 2024
7 - 14 horas
Moderada
Repairing the scratches on a wooden cutting board is a repair most people can do at home. This step-by-step guide will show how to restore a scratched wooden cutting board and make it look newer. The steps in this guide will include cleaning, sanding, and adding oil to the board. Please be careful and stay alert when using sandpaper. Sandpaper is rough on the surface and can lead to skin damage. Most people have experience using sandpaper so there shouldn't be any serious injuries.
  1. How to Remove Cutting Board Scratches, How to Remove Cutting Board Scratches: passo 1, imagem 1 %32
    • Thoroughly wash the cutting board with warm water and gentle dish soap.
    • Rinse the cutting board to make sure all the soap is removed.
  2. How to Remove Cutting Board Scratches: passo 2, imagem 1 %32
    • Pat the cutting board dry with a towel.
    • Allow the cutting board to completely air dry.
  3. How to Remove Cutting Board Scratches: passo 3, imagem 1 %32
    • Use a fine grit sandpaper (220-grit) and gently sand the scratched sections of the board.
    • Use even pressure until the scratches disappear.
  4. How to Remove Cutting Board Scratches: passo 4, imagem 1 %32
    • Remove any dust or residue using a damp towel.
    • Make sure the cutting board is completely clean and dry before moving on to the next step.
  5. How to Remove Cutting Board Scratches: passo 5, imagem 1 %32
    • Pour a generous amount of food-safe oil onto the surface of the board.
    • The amount will vary depending on the size of the board.
    • Allow the oil to soak into the cutting board overnight.
    • Wipe off any excess oil.
    • If there are still scratches visible on the cutting board, repeat all steps if necessary.
Linha de Chegada
Preethi Thomas
Membro desde: 05/29/24
121 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 89
