Ir para o conteúdo principal
How to Reinsert a Wooden Chair Side Stretcher
Shaelyn
Shaelyn e 2 outros colaboradores
Última atualização em May 21, 2024
1 dia
Moderado
Introdução
Ir para o passo 1
If your wooden chair's side stretcher has fallen out due to a broken dowel, use this guide for a 10 step repair that will re-insert it securely.
A chair's side stretcher helps strengthen its vertical supports and adds visual appeal to its lower section. When excessive or uneven vertical weight is put on a side stretcher, it can break the horizontal support.
Oftentimes, this break is at one of the dowels holding the stretcher in. But with a few simple tools and actions, this break can easily be fixed, as demonstrated in this guide.
Before beginning this repair, please note that the dowel size and clamp length used in the repair are specific to the size of your chair and stretcher. Make sure to note which of the chair's leg holes are for the broken dowel and the intact dowel as well. The process will take around 20 minutes with an additional 24 hours of curing time for the wood glue.
  1. How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: passo 1, imagem 1 %32 How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: passo 1, imagem 2 %32
    • Use the sandpaper to rough up the empty dowel holes on the side stretcher and the chairs legs.
  2. How to Reinsert a Wooden Chair Side Stretcher: passo 2, imagem 1 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 2, imagem 2 %32
    • Check if the new dowel fits through the stretcher hole and the leg hole.
  3. How to Reinsert a Wooden Chair Side Stretcher: passo 3, imagem 1 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 3, imagem 2 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 3, imagem 3 %32
    • Using the disposable stirrer and bowl, mix a 2:1 ratio of sawdust and wood glue.
    • The final consistency should be paste-like.
  4. How to Reinsert a Wooden Chair Side Stretcher: passo 4, imagem 1 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 4, imagem 2 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 4, imagem 3 %32
    • With the stirrer, fill in the leg hole of the broken dowel with the paste.
  5. How to Reinsert a Wooden Chair Side Stretcher: passo 5, imagem 1 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 5, imagem 2 %32
    • Apply a glob of wood glue to the other leg's hole.
    • Use the stirrer to spread the glue around the hole.
  6. How to Reinsert a Wooden Chair Side Stretcher: passo 6, imagem 1 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 6, imagem 2 %32
    • Insert the intact stretcher dowel into the leg hole with wood glue.
  7. How to Reinsert a Wooden Chair Side Stretcher: passo 7, imagem 1 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 7, imagem 2 %32
    • Align the empty stretcher hole to the the leg hole filled with paste.
    • Insert the dowel and firmly push it in till it's fully submerged into the stretcher hole.
    • Insertion of the dowel will push out some of the wood paste.
  8. How to Reinsert a Wooden Chair Side Stretcher: passo 8, imagem 1 %32 How to Reinsert a Wooden Chair Side Stretcher: passo 8, imagem 2 %32
    • Put the legs holding the stretcher between the bar clamp's jaws.
    • Screw in the handle to clamp together the legs until it is secure.
    • Putting a cloth or barrier between the clamp and the leg can prevent possible damage to the wood's surface.
  9. How to Reinsert a Wooden Chair Side Stretcher: passo 9, imagem 1 %32
    • Remove any wood glue or paste residue on the legs and stretcher with a damp paper towel.
  10. How to Reinsert a Wooden Chair Side Stretcher: passo 10, imagem 1 %32
    • Leave the chair and bar clamp in place for 24 hours while the wood glue and paste cures.
    • After waiting, screw out the clamp's handle to remove it from the chair.
Conclusão
Your chair should now resemble how it was before, with the side stretcher back in place. Happy fixing!
Uma outra pessoa concluiu este guia.
Shaelyn
Membro desde: 02/01/24
205 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-6, Andersen Winter 2024 Membro de UC Davis, Team 3-6, Andersen Winter 2024
UCD-ANDERSEN-W24S3G6
2 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 521
