Ir para o conteúdo principal
How to Reinforce a Cowboy Boot Heel
Nat Ericksen
Nat Ericksen e 2 outros colaboradores
Última atualização em December 20, 2024
25 minutos
Fácil
Introdução
Ir para o passo 1
Having the heels of your boots torn off can be extremely frustrating. Cowboy boots go through extensive wear especially because they are typically worn for physical work rather than a fashion statement. It is natural to have your boots deteriorate over time and it is recommended to repair and reinforce damaged parts as soon as possible.
If you or someone you know have a broken heel on a cowboy boot, this guide details a step-by-step process of properly repairing an unstable heel. Cheap, fast, and effective, our guide ensures an affordable and functional method for fixing your boots.
  1. How to Reinforce a Cowboy Boot Heel, How to Reinforce a Cowboy Boot Heel: passo 1, imagem 1 %32 How to Reinforce a Cowboy Boot Heel, How to Reinforce a Cowboy Boot Heel: passo 1, imagem 2 %32
    • Identify and assess the damage on the heel of your cowboy boot.
  2. How to Reinforce a Cowboy Boot Heel: passo 2, imagem 1 %32 How to Reinforce a Cowboy Boot Heel: passo 2, imagem 2 %32
    • Take a piece of sandpaper and sand down the inside of the broken heel.
    • This will allow the glue to adhere to a smooth surface.
  3. How to Reinforce a Cowboy Boot Heel: passo 3, imagem 1 %32 How to Reinforce a Cowboy Boot Heel: passo 3, imagem 2 %32 How to Reinforce a Cowboy Boot Heel: passo 3, imagem 3 %32
    • Apply a small amount of Shoe Goo to the paintbrush.
    • Use the paintbrush to apply the glue on the inside of the broken heel.
    • Shoe Goo contains strong chemicals that are unsafe to inhale in large quantities.
  4. How to Reinforce a Cowboy Boot Heel: passo 4, imagem 1 %32
    • Hold and apply pressure to the boot with your hands for at least 5 minutes.
    • Wait an additional 5 minutes for the glue to dry.
  5. How to Reinforce a Cowboy Boot Heel: passo 5, imagem 1 %32 How to Reinforce a Cowboy Boot Heel: passo 5, imagem 2 %32 How to Reinforce a Cowboy Boot Heel: passo 5, imagem 3 %32
    • Measure the length of each side of the heel with the leather strip.
    • Cut two pieces of leather using scissors corresponding to the measured length of the right and left side of the heel.
    • If the leather strips are too thick, cut the measured leather strips vertically in half for thinner strips.
  6. How to Reinforce a Cowboy Boot Heel: passo 6, imagem 1 %32 How to Reinforce a Cowboy Boot Heel: passo 6, imagem 2 %32 How to Reinforce a Cowboy Boot Heel: passo 6, imagem 3 %32
    • Apply glue to the leather strip with the paint brush.
    • Place the strip on one side of the boot along the heel.
  7. How to Reinforce a Cowboy Boot Heel: passo 7, imagem 1 %32 How to Reinforce a Cowboy Boot Heel: passo 7, imagem 2 %32
    • Apply glue to the other leather strip.
    • Place the strip onto the other side of the boot, so that both pieces meet at the back.
    • These leather strips will reinforce and protect your heel from detaching again in the future.
  8. How to Reinforce a Cowboy Boot Heel: passo 8, imagem 1 %32 How to Reinforce a Cowboy Boot Heel: passo 8, imagem 2 %32 How to Reinforce a Cowboy Boot Heel: passo 8, imagem 3 %32
    • Rub the sponge on the mink oil for 30 seconds.
    • Apply the oil to the leather parts of the boot.
    • Mink oil waterproofs, restores, and protects the leather.
  9. How to Reinforce a Cowboy Boot Heel: passo 9, imagem 1 %32
    • Enjoy your newly fixed cowboy boot!
    • Let the glue dry for 24 hours until wearing it.
Conclusão
Thank you for using our guide! Enjoy your fixed boot!
Nat Ericksen
Membro desde: 11/04/24
169 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-9, Vidal-Chiesa Fall 2024 Membro de UC Davis, Team 4-9, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G9
2 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 132
