Ir para o conteúdo principal
How to Recaulk a Toilet
DaNaria
DaNaria e 2 outros colaboradores
Última atualização em December 19, 2023
10 - 20 minutos
Fácil
Precisa de melhores imagens
Introdução
Ir para o passo 1
Hi there,
Welcome to another IFixIt repair guide, the go-to spot for all your repair needs. In this repair, we've got a common household woe on our hands - worn toilet caulk. But fear not, because we're diving headfirst into the world of toilet repairs, and are here to guide you through every step of the way. Whether you're dealing with worn caulk or damaged caulk, we've got you covered. So I guess it’s time to get our hands dirty.
  1. How to Recaulk a Toilet, Toilet Caulk: passo 1, imagem 1 %32 How to Recaulk a Toilet, Toilet Caulk: passo 1, imagem 2 %32 How to Recaulk a Toilet, Toilet Caulk: passo 1, imagem 3 %32
    • Wet a paper towel with warm water and wipe away any old caulk residue
    • Once all the residue is removed, wipe away the remaining water with a new dry paper towel until the area is completely dry.
  2. How to Recaulk a Toilet: passo 2, imagem 1 %32 How to Recaulk a Toilet: passo 2, imagem 2 %32
    • Using scissors, clip the tip of your caulk tube to it's intended length, which is indicated by a line on the tip of your caulk tube
  3. How to Recaulk a Toilet: passo 3, imagem 1 %32 How to Recaulk a Toilet: passo 3, imagem 2 %32
    • Using gentle pressure and grip, caulk around the entirety of the toilet rim
  4. How to Recaulk a Toilet: passo 4, imagem 1 %32 How to Recaulk a Toilet: passo 4, imagem 2 %32 How to Recaulk a Toilet: passo 4, imagem 3 %32
    • When you're done caulking the entirety of the rim, make soapy water by mixing liquid dish soap and warm water. Then apply the soapy water gently to the rim of the toilet.
    • Using a paper towel, wipe around the rim of to ensure that the caulk is neatly placed around the toilets rim.
  5. How to Recaulk a Toilet: passo 5, imagem 1 %32 How to Recaulk a Toilet: passo 5, imagem 2 %32 How to Recaulk a Toilet: passo 5, imagem 3 %32
    • When you feel the caulk is well laid, wipe up the remaining soapy water with a dry paper towel
Conclusão
After twenty-four hours your toilet will be recalked like new and ready to be used.
Uma outra pessoa concluiu este guia.
DaNaria
Membro desde: 10/23/23
148 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 243
