Ir para o conteúdo principal
How to Reattach a Canvas Tote Bag Strap
Jasmine Phan
Jasmine Phan e 4 outros colaboradores
Última atualização em August 23, 2023
15 minutos
Moderada
Canvas tote bags are meant to be reused, and they are a sustainable alternative to using plastic bags that are mass-produced and not eco-friendly. People often use canvas tote bags for school, groceries, gym, and more! This could include laptops, books, clothes, shoes, etc. Heavy items and natural wear and tear often cause tote bag straps to detach from the tote bag's body.
However, if a strap has detached from your tote bag, it does not mean that you need to discard the tote bag! This is a simple guide to learning how to repair your tote bag by sewing the broken strap back into place to make it as good as new.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Reattach a Canvas Tote Bag Strap, How to Reattach a Canvas Tote Bag Strap: passo 1, imagem 1 %32
    • Trim off any loose strings or threads attached to the ends of the strap and tote bag body.
  2. How to Reattach a Canvas Tote Bag Strap: passo 2, imagem 1 %32
    • Use a ruler to measure the distance from the end of an attached strap to the edge of the bag.
  3. How to Reattach a Canvas Tote Bag Strap: passo 3, imagem 1 %32
    • On the side where the tote bag strap has detached, put a mark based on your previous measurement on the inside of the bag.
    • This mark is where you want to start sewing your strap.
  4. How to Reattach a Canvas Tote Bag Strap: passo 4, imagem 1 %32 How to Reattach a Canvas Tote Bag Strap: passo 4, imagem 2 %32
    • Cut a piece of thread that is about 22–24 inches in length.
    • Pull the thread through the needle eye until the two ends of the thread are equal.
    • Double knot the two ends of the thread together.
  5. How to Reattach a Canvas Tote Bag Strap: passo 5, imagem 1 %32 How to Reattach a Canvas Tote Bag Strap: passo 5, imagem 2 %32
    • Begin sewing by weaving the needle down through the strap material and then upwards through the strap material.
    • Sew half an inch above the bottom edge of the tote bag strap in a straight line all the way across to the other end of the strap.
    • Sew about 2-3 lines with the thread. You may add more or less depending on how much strength you think it will need.
    • Stitches should be about 1-2 mm apart.
    • When sewing through the tote bag material, be careful of finger tips since needle is sharp.
    • Here is a link to an external site that will provide more detail on how to sew, along with different methods. https://www.wikihow.com/Sew
  6. How to Reattach a Canvas Tote Bag Strap: passo 6, imagem 1 %32
    • Tie off the thread by making a secure knot at the end.
  7. How to Reattach a Canvas Tote Bag Strap: passo 7, imagem 1 %32 How to Reattach a Canvas Tote Bag Strap: passo 7, imagem 2 %32
    • Cut off the extra thread.
    • Once you finish, your tote bag should look like this.
Conclusão
Repeat all of the steps for any remaining detached straps.
Jasmine Phan
Membro desde: 02/02/23
145 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-1, Andersen Winter 2023 Membro de UC Davis, Team 4-1, Andersen Winter 2023
UCD-ANDERSEN-W23S4G1
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 54
Duração total: 2,661
