Ir para o conteúdo principal
How to Realign the Motor in a Space Heater
Adam Moser
Adam Moser e 5 outros colaboradores
Última atualização em February 6, 2023
30 minutos
Moderado
Introdução
Ir para o passo 1
The Comfort Zone CZ442 will produce a loud screeching noise if the motor is jolted out of alignment. Left in this state, the motor may eventually burn out completely. This guide covers the realignment of the motor.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Realign the Motor in a Space Heater, How to Realign the Motor in a Space Heater: passo 1, imagem 1 %32
    • Before you begin, unplug the heater from the outlet.
    • Remove the four rear Phillips screws. Apply firm pressure when removing all screws to prevent stripping.
  2. How to Realign the Motor in a Space Heater: passo 2, imagem 1 %32 How to Realign the Motor in a Space Heater: passo 2, imagem 2 %32
    • Carefully remove the front heater panel.
  3. How to Realign the Motor in a Space Heater: passo 3, imagem 1 %32 How to Realign the Motor in a Space Heater: passo 3, imagem 2 %32 How to Realign the Motor in a Space Heater: passo 3, imagem 3 %32
    • Remove the four Phillips mounting screws from the heater assembly.
  4. How to Realign the Motor in a Space Heater: passo 4, imagem 1 %32 How to Realign the Motor in a Space Heater: passo 4, imagem 2 %32
    • Slide the top control switch panel out. Be careful not to pull, or apply excess pressure to, any of the wires.
  5. How to Realign the Motor in a Space Heater: passo 5, imagem 1 %32
    • Using pliers, remove the fan’s center mounting nut.
  6. How to Realign the Motor in a Space Heater: passo 6, imagem 1 %32
    • Pull firmly to remove the fan from the motor.
    • Pull from the center of the fan. Do not pull on the fan blades.
  7. How to Realign the Motor in a Space Heater: passo 7, imagem 1 %32 How to Realign the Motor in a Space Heater: passo 7, imagem 2 %32
    • Slightly loosen both of the motor retainer screws about one full rotation.
  8. How to Realign the Motor in a Space Heater: passo 8, imagem 1 %32
    • Push down on the motor bracket and adjust the motor by hand so it spins freely and does not scrape.
  9. How to Realign the Motor in a Space Heater: passo 9, imagem 1 %32
    • Turn the thermostat selector fully clockwise, and the heater selector to “Fan.”
    • Make sure that the heater selector is clearly turned to the "Fan" setting. Any other setting could cause burns, fire, or electric shock.
  10. How to Realign the Motor in a Space Heater: passo 10, imagem 1 %32 How to Realign the Motor in a Space Heater: passo 10, imagem 2 %32 How to Realign the Motor in a Space Heater: passo 10, imagem 3 %32
    • Make sure the safety switch on the bottom of the heater is not being pressed. Wear the leather gloves, and plug in the heater.
    • The safety switch's normal function is to turn off the heater automatically if it tips over. Here, however, we can use it as a button to test the fan.
  11. How to Realign the Motor in a Space Heater: passo 11, imagem 1 %32 How to Realign the Motor in a Space Heater: passo 11, imagem 2 %32
    • Press the safety switch briefly to confirm that the motor can spin. Slightly tighten the screws and adjust the motor's alignment by hand until it can spin freely. A light rattling or noise is fine and will be fixed later.
    • Keep your fingers clear of the motor while it is spinning.
  12. How to Realign the Motor in a Space Heater: passo 12, imagem 1 %32
    • Stand the heater case up, so the safety switch is pressed, and the motor is on.
  13. How to Realign the Motor in a Space Heater: passo 13, imagem 1 %32 How to Realign the Motor in a Space Heater: passo 13, imagem 2 %32
    • While the motor is running, slowly tighten the retainer screws until the motor runs smoothly and quietly.
    • If the screws are too loose, the motor will rattle or screech. If the screws are too tight, the motor cannot turn.
  14. How to Realign the Motor in a Space Heater: passo 14, imagem 1 %32
    • Set the case back on its side, so the safety switch is no longer pressed, and the motor turns off.
  15. How to Realign the Motor in a Space Heater: passo 15, imagem 1 %32
    • Align the fan to the motor axle, and press firmly to reattach it.
    • Press on the center of the fan only. Do not push on the fan blades.
  16. How to Realign the Motor in a Space Heater: passo 16, imagem 1 %32
    • Briefly press the bottom safety switch to verify that the fan runs smoothly and quietly. If it does not, return to step 6.
    • Make sure your hands and other objects are clear of the fan
  17. How to Realign the Motor in a Space Heater: passo 17, imagem 1 %32
    • Unplug the heater.
  18. How to Realign the Motor in a Space Heater: passo 18, imagem 1 %32 How to Realign the Motor in a Space Heater: passo 18, imagem 2 %32 How to Realign the Motor in a Space Heater: passo 18, imagem 3 %32
    • Reverse steps one through five to reassemble the heater.
  19. How to Realign the Motor in a Space Heater: passo 19, imagem 1 %32
    • Test the heater to verify that everything is working quietly and properly
Linha de Chegada
6 outras pessoas executaram este guia.
Adam Moser
Membro desde: 02/10/16
191 Reputação
Autoria de 1 guia
Equipe
2Comentários do guia
Worked perfectly, thank you.
Christopher Richard - Responder
The shaft on mine still moves in and out. Any suggestions?
Jonathan Williamsburg - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 6,630
