How to Patch a Torn Window Screen
Introdução
Ir para o passo 1A tear on your window screen renders the screen useless. But if the tear has not pulled the mesh out of the frame and/or is not extremely large, then a full replacement—which can be costly and labor intensive— should not be necessary. This fix will guide you through fixing a tear on a screen easily and cost effectively. All you will need are some scissors, pliers or tweezers, and some patching mesh.
O que você precisa
Ferramentas
Exibir mais…
Remove the screen from the window frame and place it in your work space.
Your window screen is now patched. Feel free to once again open your window and let the breeze in without any pesky bugs or debris flying through the tear!
Gear Up For Future Repairs
Shop all
