Ir para o conteúdo principal
How to Patch a Hole in Pullover Hoodie with Fabric
Thi Anh Thu Dao
Thi Anh Thu Dao e 3 outros colaboradores
Última atualização em December 20, 2024
15 - 20 minutos
Moderado
Introdução
Ir para o passo 1
Branches, sharp objects, or even standard wear-and-tear can cause holes and tears of many varieties to appear in your clothing. This guide serves as a resource to assist you in taking the steps needed to patch fabric on your clothing and restore your hoodie to working order again.
Before You Begin:
  • Check the Damage: Ensure the hole is manageable for patching. Advanced techniques might be required if it's too large or near a seam.
  • Choose the Right Material: Select fabric similar to the hoodie’s material and stretch for a seamless repair.
  • Prioritize Safety: Handle sharp tools like scissors and needles with care to avoid injury.
Repairing your hoodie saves money, reduces waste, lets you personalize your clothes, and helps you learn a useful new skill!
  1. How to Patch a Hole in Pullover Hoodie with Fabric, How to Patch a Hole in Pullover Hoodie with Fabric: passo 1, imagem 1 %32 How to Patch a Hole in Pullover Hoodie with Fabric, How to Patch a Hole in Pullover Hoodie with Fabric: passo 1, imagem 2 %32
    • Identify the hole and measure a square that covers the damaged area, noting the length and width in millimeters (mm).
  2. How to Patch a Hole in Pullover Hoodie with Fabric: passo 2, imagem 1 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 2, imagem 2 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 2, imagem 3 %32
    • Before marking the new measurements on the replacement fabric, ensure that there is a quarter-inch gap on all sides.
    • Place a mark for each side of the previously gathered measurements.
  3. How to Patch a Hole in Pullover Hoodie with Fabric: passo 3, imagem 1 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 3, imagem 2 %32
    • Cut the replacement fabric along the marked dots, ensuring that the quarter-inch space before each mark is included in the cut.
  4. How to Patch a Hole in Pullover Hoodie with Fabric: passo 4, imagem 1 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 4, imagem 2 %32
    • Cut a length of thread that is approximately twice the perimeter of the square patch.
    • Thread the needle and tie a knot at the end to secure it.
    • A more detailed guide on how to tie a knot can be found here.
  5. How to Patch a Hole in Pullover Hoodie with Fabric: passo 5, imagem 1 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 5, imagem 2 %32
    • Place the fabric over the damaged area, ensuring it fully covers the damaged area.
    • Begin a temporary stitch by inserting the needle in and out of the fabric at evenly spaced intervals to create a dashed line.
    • Once finished, tie a secure knot and cut the thread to free the needle.
  6. How to Patch a Hole in Pullover Hoodie with Fabric: passo 6, imagem 1 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 6, imagem 2 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 6, imagem 3 %32
    • Re-thread the needle with a new piece of thread and knot.
    • With a new colored thread, begin a permanent stitch with tighter spacing using the same technique.
  7. How to Patch a Hole in Pullover Hoodie with Fabric: passo 7, imagem 1 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 7, imagem 2 %32 How to Patch a Hole in Pullover Hoodie with Fabric: passo 7, imagem 3 %32
    • Tie a knot and trim excess thread close to the knot.
    • Cut open the temporary stitch to remove it.
  8. How to Patch a Hole in Pullover Hoodie with Fabric: passo 8, imagem 1 %32
    • Once the patch is completely sewn, trim the patch as desired to ensure neatness.
Conclusão
Be sure to trim as desired should more strands of the patch become free. You now have a refreshed hoodie with a sturdy and stylish patch!
Thi Anh Thu Dao
Membro desde: 11/07/24
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-4, Vidal-Chiesa Fall 2024 Membro de UC Davis, Team 3-4, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G4
3 Membros
1 Guia de autoria
1Comentário do guia
I think I might have put the patch on the inside of the garment. Might have looked neater.
Callie - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 247
