Ir para o conteúdo principal
How to Patch a Hole in Jeans with Wool
LiTong Liu
LiTong Liu e 2 outros colaboradores
Última atualização em June 5, 2024
30 minutos
Moderado
Introdução
Ir para o passo 1
Here's a guide on how to patch a small hole in jeans using wool and a technique called needle felting.
Needle felting is a craft technique that uses special felting needles to intertwine wool fibers, creating a solid fabric. When used to patch a hole in jeans, the wool fibers not only bind together but also intertwine with the jean fabric, effectively patching the hole.
  1. How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: passo 1, imagem 1 %32 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: passo 1, imagem 2 %32 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: passo 1, imagem 3 %32
    • Cut a piece of felt large enough to cover the hole
  2. How to Patch a Hole in Jeans with Wool: passo 2, imagem 1 %32 How to Patch a Hole in Jeans with Wool: passo 2, imagem 2 %32
    • Insert thread through the needle hole.
  3. How to Patch a Hole in Jeans with Wool: passo 3, imagem 1 %32 How to Patch a Hole in Jeans with Wool: passo 3, imagem 2 %32 How to Patch a Hole in Jeans with Wool: passo 3, imagem 3 %32
    • Make a loop at the end of the thread.
    • Pull the end of the thread through the loop creating a knot.
  4. How to Patch a Hole in Jeans with Wool: passo 4, imagem 1 %32 How to Patch a Hole in Jeans with Wool: passo 4, imagem 2 %32 How to Patch a Hole in Jeans with Wool: passo 4, imagem 3 %32
    • Grab the end of the jean with your hand.
    • Pull the jean towards you, making it inside out.
    • Place the felt on the hole.
  5. How to Patch a Hole in Jeans with Wool: passo 5, imagem 1 %32 How to Patch a Hole in Jeans with Wool: passo 5, imagem 2 %32 How to Patch a Hole in Jeans with Wool: passo 5, imagem 3 %32
    • Pinch together the jean and the felt.
    • Insert the needle horizontally into the jean and edge of the felt.
    • Pull the needle through till the knot touches the felt.
    • Repeat the above steps until the border of the felt is stitched.
    • Make a knot at the end.
    • Cut off excess thread.
  6. How to Patch a Hole in Jeans with Wool: passo 6, imagem 1 %32 How to Patch a Hole in Jeans with Wool: passo 6, imagem 2 %32 How to Patch a Hole in Jeans with Wool: passo 6, imagem 3 %32
    • Grasp the end of the jeans and pull them towards you to turn them right side out.
    • Insert the foam board into the pants and position it underneath the hole.
  7. How to Patch a Hole in Jeans with Wool: passo 7, imagem 1 %32 How to Patch a Hole in Jeans with Wool: passo 7, imagem 2 %32 How to Patch a Hole in Jeans with Wool: passo 7, imagem 3 %32
    • Grab more than enough wool to cover the size of your hole, ensuring it is at least an inch thick.
    • Rub the wool between hands to make a ball.
    • Place the wool on top of the hole.
  8. How to Patch a Hole in Jeans with Wool: passo 8, imagem 1 %32 How to Patch a Hole in Jeans with Wool: passo 8, imagem 2 %32 How to Patch a Hole in Jeans with Wool: passo 8, imagem 3 %32
    • Stab the wool through the jean and onto the foam board.
    • Repeat until the wool is hardened.
  9. How to Patch a Hole in Jeans with Wool: passo 9, imagem 1 %32 How to Patch a Hole in Jeans with Wool: passo 9, imagem 2 %32 How to Patch a Hole in Jeans with Wool: passo 9, imagem 3 %32
    • Rub some soap onto the wool to tangle the fibers.
    • Place the jeans into the laundry machine.
    • Wash on cold and air dry.
    • Wear your cute mended pants!
Linha de Chegada
LiTong Liu
Membro desde: 04/25/24
169 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-2, Whithaus Spring 2024 Membro de UC Davis, Team 1-2, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G2
3 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 123
Ao todo: 652
