How to Mend Broken China
Introdução
Ir para o passo 1China is delicate and will often break due to daily use and careless handling. This guide will show you how to effectively mend plain, slightly broken china using a clear epoxy filler.
Tip: You can add any pigment to the epoxy, making the cracks less visible and the repair more subtle.
O que você precisa
Ferramentas
Exibir mais…
Wipe all broken edges with rubbing alcohol using a paper towel.
Will I be able to drink/eat from chino repaired with epoxy? Is it washable? Paintable? Microwaveable?
3 outras pessoas executaram este guia.
