How to Make a Jeans Patch Less Noticeable
Introdução
Ir para o passo 1This repair guide demonstrates how to not only fix a hole in jeans but also make the hole less prominent. Patching a hole in the pocket is easy but sometimes the color of the patch doesn’t match the jeans, making it look awkward. Creating a design on the backside of the jeans will repurpose jeans that were not going to be worn. This will ultimately reduce waste because it allows us to repurpose a pair of jeans that would have been discarded.
O que você precisa
Ferramentas
Exibir mais…
Place the jeans on an even surface.
Flip your jeans inside out.
Grabbing a new color thread, tie off a knot like mentioned in step 4.
Starting inside, create your desired design (we decided a moon and stars).
Push the needle back to front creating little clumps within the hole.
When you have finished the design tie it off on the inside of the jeans.
Cut a new piece of thread and place it on the inside.
Push the needle back to front of the jeans and push it back inside a few centimeters down.
Repeat this threading technique a few times, creating a star.
Tie off the thread on the inside of the jean.
Cut any excess thread from the inside of the jean.
Jeans are now ready to be worn.
