Ir para o conteúdo principal
How to Lubricate a Zipper
Brittany McCrigler
Brittany McCrigler e 4 outros colaboradores
Última atualização em March 9, 2025
5 minutos
Muito fácil
Introdução
Ir para o passo 1
The most common reason zippers get stuck is that dirt and debris often lodges in the zipper slider. Cleaning and lubricating your zipper helps to extend its life and prevents sticking, oxidizing, and jamming. The procedure we describe here works for both coil zippers and plastic tooth zippers. Lubricate your zipper after you’ve been in a dusty, dirty or wet environment.
O que você precisa
  1. How to Lubricate a Zipper, How to Lubricate a Zipper: passo 1, imagem 1 %32 How to Lubricate a Zipper, How to Lubricate a Zipper: passo 1, imagem 2 %32 How to Lubricate a Zipper, How to Lubricate a Zipper: passo 1, imagem 3 %32
    • Lay your garment on a table.
    • If you can, unzip the zipper.
    • If you can't move the slider, just work around it.
    • Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
  2. How to Lubricate a Zipper: passo 2, imagem 1 %32 How to Lubricate a Zipper: passo 2, imagem 2 %32
    • Pinch the slider in your fingers, so that you can see into the area where the coil rests.
    • Use the brush to free any dirt or debris caught inside the slider.
  3. How to Lubricate a Zipper: passo 3, imagem 1 %32 How to Lubricate a Zipper: passo 3, imagem 2 %32 How to Lubricate a Zipper: passo 3, imagem 3 %32
    • Place a paper towel behind the zipper.
    • To prevent messes, make sure that the paper towel is touching the underside of the teeth or coil.
  4. How to Lubricate a Zipper: passo 4, imagem 1 %32 How to Lubricate a Zipper: passo 4, imagem 2 %32 How to Lubricate a Zipper: passo 4, imagem 3 %32
    • Twist open the Zip Care.
    • Gently squeeze the bottle as you slide the brush along the teeth or coil of the zipper to apply the lubricant.
    • Repeat this on both sides of the zipper teeth or coil.
  5. How to Lubricate a Zipper: passo 5, imagem 1 %32 How to Lubricate a Zipper: passo 5, imagem 2 %32
    • Fold the paper towel over and dab any excess lubricant off the zipper.
  6. How to Lubricate a Zipper: passo 6, imagem 1 %32 How to Lubricate a Zipper: passo 6, imagem 2 %32
    • Zip and unzip the zipper a few times to work the lubricant in between the teeth or coil.
Linha de Chegada
6 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.748 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.537 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 74
Últimos 30 dias: 421
Ao todo: 117,582
