Ir para o conteúdo principal
How to Install a Heatsink on an M.2 SSD
O que você precisa
  1. How to Install a Heatsink on an M.2 SSD, Prepare the first thermal pad: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    • The heatsink uses thermal pads to dissipate heat from either side of the blade SSD. The thermal pads may come with plastic liners on each side, so make sure all are removed before use.
    • Use a pair of tweezers to peel one side of protective film away from one of the thermal pads.
  2. How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: passo 2, imagem 1 %32 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: passo 2, imagem 2 %32 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: passo 2, imagem 3 %32
    • Align the exposed side of the thermal pad with the bottom tray section of the heatsink assembly.
    • Lay the thermal pad down so it covers the tray evenly.
    • Use your finger to lightly press down on the thermal pad to adhere it to the surface.
  3. How to Install a Heatsink on an M.2 SSD, Prepare the second thermal pad: passo 3, imagem 1 %32
    • Use a pair of tweezers to peel one side of protective film away from the remaining thermal pad.
  4. How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: passo 4, imagem 1 %32 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: passo 4, imagem 2 %32 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: passo 4, imagem 3 %32
    • Align the exposed side of the thermal pad with the top section of the heatsink.
    • Lay the thermal pad down so it covers the top section evenly.
  5. How to Install a Heatsink on an M.2 SSD, Remove the bottom thermal pad liner: passo 5, imagem 1 %32
    • Use a pair of tweezers to remove the plastic liner from the thermal pad in the tray.
    • The thermal pad might lift up from the tray as the liner is removed—this is normal. Use your finger to keep the pad in the tray.
  6. How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: passo 6, imagem 1 %32 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: passo 6, imagem 2 %32 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: passo 6, imagem 3 %32
    • Lay the M.2 SSD into the tray, the side with the most chips facing up.
    • Make sure the SSD is centered in the tray. The tray shouldn't cover the contacts or the screw cutout.
  7. How to Install a Heatsink on an M.2 SSD, Remove the top thermal pad liner: passo 7, imagem 1 %32
    • Use a pair of tweezers to remove the plastic liner from the thermal pad on the heatsink's top section.
    • The thermal pad might lift up from the heatsink as the liner is removed—this is normal. Use your finger to keep the pad in place.
  8. How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: passo 8, imagem 1 %32 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: passo 8, imagem 2 %32 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: passo 8, imagem 3 %32
    • Align the top heatsink section over the SSD and the tray.
    • Firmly press the two halves together. You'll feel it "snap" into place.
  9. How to Install a Heatsink on an M.2 SSD, Check the alignment: passo 9, imagem 1 %32
    • For the SSD to fit in a desktop PC or a PlayStation 5, the heatsink needs to be centered on the SSD.
    • Make sure that the heatsink is close to the screw cutout but doesn't overhang it.
    • If you're having trouble installing your SSD, you may have to slightly adjust the heatsink's position.
    • Use your fingers to slide the SSD between the two halves of the heatsink assembly until fitment is just right.
Conclusão
Installation didn’t go as planned? Check out our Computer Hardware Answers community or PlayStation 5 Answers community for troubleshooting help.
8 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
155.295 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
4Comentários do guia
If your SSD has a big "warranty void if removed" sticker over the chips, do you have to remove it? Or can you stick the thermal pad over that sticker?
shamino - Responder
You can leave the sticker on the SSD! Just make sure to remove any adhesive liners on the thermal pad.
Carsten Frauenheim -
I just bought predator gm7000 ssd with heatsink. The ssd only come with one thermal pad on top to be use with the heatsink. Do i need to get another thermal pad for bottom?
afiqtobi9 - Responder
This is just a generic guide, so not every step applies to every situation. I've checked your mentioned SSD and it comes with a custom heatsink for it, which means you don't need another one. Thermal pads only help if they're touching a surface (i.e. a metal sheet) for heat transfer. Since this isn't how yours is build/installed, a second pad would be basically pointless. Hope this helps :)
Kongoduff -
Comentar
Visualizações:
Últimas 24 horas: 86
Últimos 7 dias: 565
Últimos 30 dias: 2,261
Ao todo: 94,039
