Ir para o conteúdo principal
How to Install a Fifth String Shubb Banjo Capo
O que você precisa
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, imagem 1 %32 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, imagem 2 %32 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, imagem 3 %32
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: passo 2, imagem 1 %32
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: passo 3, imagem 1 %32
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: passo 4, imagem 1 %32 How to Install a Fifth String Shubb Banjo Capo: passo 4, imagem 2 %32
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: passo 5, imagem 1 %32 How to Install a Fifth String Shubb Banjo Capo: passo 5, imagem 2 %32 How to Install a Fifth String Shubb Banjo Capo: passo 5, imagem 3 %32
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
Conclusão
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 outras pessoas executaram este guia.
Sara Wier
Membro desde: 02/24/15
263 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-4, Green Winter 2015 Membro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
Membros da 7
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 31
Duração total: 6,517
