Ir para o conteúdo principal
How to Install a Fifth String Shubb Banjo Capo
Sara Wier
Sara Wier e 6 outros colaboradores
Última atualização em August 9, 2019
15 minutos
Moderado
Introdução
Ir para o passo 1
Use basic skills and handy work to install a capo that will expand the library of tablature available to your musical abilities. A fifth string capo is intended to adjust the tuning of the fifth (G) string on the banjo without having to constantly adjust the fifth string tuning key.
This installation process can be pretty intimidating, but if you approach it cautiously and double check your measurements, this fix can be empowering and rewarding.
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, imagem 1 %32 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, imagem 2 %32 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: passo 1, imagem 3 %32
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: passo 2, imagem 1 %32
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: passo 3, imagem 1 %32
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: passo 4, imagem 1 %32 How to Install a Fifth String Shubb Banjo Capo: passo 4, imagem 2 %32
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: passo 5, imagem 1 %32 How to Install a Fifth String Shubb Banjo Capo: passo 5, imagem 2 %32 How to Install a Fifth String Shubb Banjo Capo: passo 5, imagem 3 %32
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
Conclusão
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 outras pessoas executaram este guia.
Sara Wier
Membro desde: 02/24/15
263 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-4, Green Winter 2015 Membro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Membros
Autoria de 15 guias
1Comentário do guia
thank you. Now, I know how to do and i décide to buy a shubb and to install it
Jean-Denis Del - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 42
Ao todo: 7,475
