Ir para o conteúdo principal
How to Hard Restart an Android Phone
Nicholas Kowalski
Nicholas Kowalski e 4 outros colaboradores
Última atualização em 6 de ago de 2025
30 segundos - 1 minuto
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
A hard restart is a process of restarting a device, such as a smartphone, tablet, or computer, by manually shutting it off and turning it back on again. It is also known as a "force restart" or "hard reset."
A hard restart is different from a soft restart, which is a normal restart of the device that can be performed by selecting the "Restart" option from the device's settings menu. A hard restart is usually done when the device is not responding or has frozen, and it can help resolve some software issues. However, it is important to note that a hard restart may cause the device to lose any unsaved data or settings.
  1. How to Hard Restart an Android Phone, Holding down the Power Button: passo 1, imagem 1 %32
    • Hold down the power button for 15 to 30 seconds, until the phone screen turns black and restarts.
    • On Samsung devices you might need to hold down the volume-down button and power button for 7 seconds instead.
    How do I restart phone if it’s flashing on and off I have a Stratus C7.
    Leon Hollie - Responder
  2. How to Hard Restart an Android Phone, Wait: passo 2, imagem 1 %32
    • Wait for the phone to finish restarting.
Conclusão
Unlock your phone and you've just hard restarted/rebooted your Android device.
116 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Nicholas Kowalski
Membro desde: 04/25/18
2.276 Reputação
Autoria de 1 guia
13Comentários do guia
Their are so many users of windows 10 don’t have any idea how to use alarms windows 10 i found this web page very informative.
Neha Sharma - Responder
My samsung J7max is not accepting even the correct pin.. even after restart the phone after fully discharged the battery
Amita Atpadkar - Responder
Please give solution
How do I upright due to the contract
Jennifer Aron - Responder
The difficulty rating should be master… two steps is just too many. Seriously, thank you. I can’t believe I didn’t think of doing this
Charles Hanes - Responder
My android want come on. On the front of the phone it says select Boot Mode
1. Recovery
2.Fastboot and 3. Normal. What do i do? It want turn off
Angie Tapp King - Responder
My android smart phone wont start , what buttons do i hold to get into a re boot or just start.
Vicki - Responder
shashikumar748800@gmail.com
Svathi - Responder
10.or e phone start problem , it doesn't start . If start then only showing company name after that either switch off or continuous showing the company name . I tried by various ways like power button + volume up button . But problem doesn't solve . I also spend my 300 rs to solve the problem . But it was totally waste . Plz suggest the best solution.
Jayakumari - Responder
Comentar
Visualizações:
Últimas 24 horas: 71
Últimos 7 dias: 368
Últimos 30 dias: 1,815
Ao todo: 152,156
