Ir para o conteúdo principal
How to Grip a Hiking Pole
Ben Blischke
Ben Blischke e um outro colaborador
Última atualização em September 22, 2024
15 minutos
Fácil
Guia colaborativo
Properly gripping your hiking pole is crucial for stability and comfort on the trails. Whether you’re a seasoned hiker or just starting out, ensuring your hiking pole is in top shape and your grip is secure can make a big difference. We will show you a quick and creative fix that will solve the problem in no time!
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Grip a Hiking Pole, Prepare the repair tools: passo 1, imagem 1 %32 How to Grip a Hiking Pole, Prepare the repair tools: passo 1, imagem 2 %32
    • Find a replacement grip tape to fix your pole.
    • Note: In this example we used the grip tape for tennis and badminton rackets.
  2. How to Grip a Hiking Pole, Prepare the grip tape: passo 2, imagem 1 %32 How to Grip a Hiking Pole, Prepare the grip tape: passo 2, imagem 2 %32 How to Grip a Hiking Pole, Prepare the grip tape: passo 2, imagem 3 %32
    • Open the grip tape and look for the diagonal tip of the tape. Set aside the sticker wrap (green arrow). This will be useful for the final part of the repair.
    • Tip: in order to identify the right tip, put both ends side to side and look for the one that has a "diagonal" shape (orange arrow).
  3. How to Grip a Hiking Pole, Wrap the tape: passo 3, imagem 1 %32 How to Grip a Hiking Pole, Wrap the tape: passo 3, imagem 2 %32 How to Grip a Hiking Pole, Wrap the tape: passo 3, imagem 3 %32
    • Remove the sticker back (red circle) of the tip and and begin to wrap the tape around the grip.
    • Make sure you begin at the end of the grip and start to wrap it upwards, keeping it tight at all times.
  4. How to Grip a Hiking Pole, Keep wrapping the grip: passo 4, imagem 1 %32 How to Grip a Hiking Pole, Keep wrapping the grip: passo 4, imagem 2 %32 How to Grip a Hiking Pole, Keep wrapping the grip: passo 4, imagem 3 %32
    • Continue to wrap the tape around the grip until you reach the end of handle.
  5. How to Grip a Hiking Pole, Cut the tip of the tape: passo 5, imagem 1 %32 How to Grip a Hiking Pole, Cut the tip of the tape: passo 5, imagem 2 %32 How to Grip a Hiking Pole, Cut the tip of the tape: passo 5, imagem 3 %32
    • Once you have reached the end of the grip, it is time to cut the end of the tip.
    • Follow the red line to cut it in a "diagonal shape".
  6. How to Grip a Hiking Pole, Close the new grip: passo 6, imagem 1 %32 How to Grip a Hiking Pole, Close the new grip: passo 6, imagem 2 %32 How to Grip a Hiking Pole, Close the new grip: passo 6, imagem 3 %32
    • Use the sticker wrap that came with the tape to close the new grip and set it in place.
  7. How to Grip a Hiking Pole, Finished and ready!: passo 7, imagem 1 %32 How to Grip a Hiking Pole, Finished and ready!: passo 7, imagem 2 %32 How to Grip a Hiking Pole, Finished and ready!: passo 7, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 24
Duração total: 152
