Ir para o conteúdo principal
How to Format a drive in Windows 7-11
O que você precisa
    1. How to Format a drive in Windows 7-11, Open File Explorer: passo 1, imagem 1 %32
      • Open File Explorer.
      • You can do that from either of the red highlighted spots, or search for "File Explorer."
      Pergunte ao FixBot
      Comentar
    2. How to Format a drive in Windows 7-11, Open the Format Menu: passo 2, imagem 1 %32 How to Format a drive in Windows 7-11, Open the Format Menu: passo 2, imagem 2 %32
      • Right-Click on the drive you want to format, and click format
      • This is what should pop up.
      Pergunte ao FixBot
      Comentar
    3. How to Format a drive in Windows 7-11, Format your drive: passo 3, imagem 1 %32
      • If you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended.
      • FAT32 has a 4GB limit on single file size.
      • Use default allocation size.
      • If you want to rename your drive, put the new name here.
      • Start the format. When It's done, you can close all the windows, and you are done.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
6 outras pessoas executaram este guia.
George A.
Membro desde: 12/07/16
22.563 Reputação
Autoria de 4 guias
Equipe
Community Protectors Membro de Community Protectors
Community
21 Membros
Autoria de 104 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 81
Ao todo: 4,457
