Ir para o conteúdo principal
How to Fix an Umbrella Rivet
Alexandra Hamelin
Alexandra Hamelin e 8 outros colaboradores
Última atualização em 14 de out de 2024
5 - 10 minutos
Fácil
Ajustador de passo
Introdução
Ir para o passo 1
This guide will show users how to fix the stretcher of an umbrella by using a thin piece of copper wire in place of where the rivet once was.
URL for half-hitch knot:
http://www.animatedknots.com/halfhitch/#...
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. How to Fix an Umbrella Rivet, How to Fix an Umbrella Rivet: passo 1, imagem 1 %32
    • Open the umbrella into its proper position.
  2. How to Fix an Umbrella Rivet: passo 2, imagem 1 %32
    • Identify the broken stretcher that needs to be repaired.
  3. How to Fix an Umbrella Rivet: passo 3, imagem 1 %32
    • Close the umbrella halfway to release the tension in the stretchers.
    • This makes it easier to line up the holes in the next step.
  4. How to Fix an Umbrella Rivet: passo 4, imagem 1 %32
    • Take the two pieces of the broken stretcher and line up the rivet holes.
  5. How to Fix an Umbrella Rivet: passo 5, imagem 1 %32
    • Pass the 6" piece of wire through the rivet holes.
  6. How to Fix an Umbrella Rivet: passo 6, imagem 1 %32
    • Wrap the wire around the stretcher and thread it through the holes again.
    • Repeat until there is no more room to pass the wire through.
    • May need to use the pliers to get a better grip on the wire so it can be pulled tight.
  7. How to Fix an Umbrella Rivet: passo 7, imagem 1 %32
    • Tie two half-hitch knots with the wire.
    • If you do not know how to tie a half-hitch knot, follow the link provided at the beginning of the guide.
    You could also just twist the ends of the wire around and around until they are all twisted together, then cut at a length of about 1/2 inch or so and then tuck in as best you can so that it doesn’t stick out.
    Lou - Responder
  8. How to Fix an Umbrella Rivet: passo 8, imagem 1 %32
    • Use the scissors to trim the two ends of the wire to about half an inch in length.
  9. How to Fix an Umbrella Rivet: passo 9, imagem 1 %32
    • Using the pliers, twist the ends of the wire together.
  10. How to Fix an Umbrella Rivet: passo 10, imagem 1 %32
    • Tuck the wires down and clamp with the pliers so the ends are not poking out.
Linha de Chegada
7 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Equipe
Texas Tech, Team 3-8, Rauch SU 2016 Membro de Texas Tech, Team 3-8, Rauch SU 2016
TTU-RAUCH-SU16S3G8
2 Membros
Autoria de 5 guias
7Comentários do guia
This is not called an ‘umbrella rivet replacement’.
SouthPark - Responder
I fixed my umbrella! Thank you. Umbrella is very old though, will see how much more time I can buy with this fix :)
Lou - Responder
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
Lou - Responder
6 months later and paperclip fix is still holding!
Lou -
Thanks! A paperclip worked!
Mayra L. -
19 months and still holding :)
Lou -
it might work for some for a temp fix But I tried this and it will not work.
it will bind and it will not close like it is supposed to
Wayne Faulkenberry - Responder
Comentar
Visualizações:
Últimas 24 horas: 18
Últimos 7 dias: 119
Últimos 30 dias: 499
Ao todo: 28,980
