How to Fix a Wobbly Leg on a Solid Wood Chair
Introdução
Ir para o passo 1Wobbly chairs are not only uncomfortable, but often carry a safety risk.
This guide takes you through a method of reinforcing wobbly wooden chair legs through the use of metal L-brackets. Some level of experience with a cordless drill is preferable for this fix, though some minor handling instructions are covered in the guide.
O que você precisa
Peças
Ferramentas
Exibir mais…
First, thoroughly assess your chair for loose elements.
Sit and jiggle them to test and note exactly what moves.
Reassemble any remaining loose pieces as they were disassembled unless otherwise noted.
3 outras pessoas executaram este guia.
2Comentários do guia
My entire corner wood pieces are broken and not fixable and the screen (bolt and nut) is bended also. I would like to purchase those small wood pieces, I am not a saavy. Need some help to find the pieces. you can mail me @ radhu_murali@hotmail.com.
My neighbor called and said she had a table. She brought it outside but before I could make it across the street someone took the legs. Miraculously I found legs from another table the next day. Unfortunately the screw hole didn’t match. The table was wobbly. This is the almost perfect fix.
