Ir para o conteúdo principal
How to Fix a Tear in a Jacket Lining
Electra Pyatt
Electra Pyatt e um outro colaborador
Última atualização em June 3, 2021
15 - 20 minutos
Moderado
Introdução
Ir para o passo 1
This guide will show you how to repair the ripped lining on a jacket and/or coat. Due to multiple uses, jackets and coats start to wear out and tear over time on lining. This will show people how to repair any tears that form on the lining of their jackets and/or coats. A lot of people deal with having to stop wearing their favorite jackets and coats due to tears. This guide can help repair those tears in minutes. Having to constantly throw out and buy new clothes because of rips can be expensive. By following these repair steps, this can help reduce peoples clothing consumption and clothes pollution. It will stop unwanted clothes from being found in landfills when thrown out.
  1. How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: passo 1, imagem 1 %32 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: passo 1, imagem 2 %32 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: passo 1, imagem 3 %32
    • Turn the jacket inside out.
  2. How to Fix a Tear in a Jacket Lining: passo 2, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 2, imagem 2 %32
    • Put the thread through the needle hole.
    • Use thread that is the same color as the material you are sewing.
  3. How to Fix a Tear in a Jacket Lining: passo 3, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 3, imagem 2 %32 How to Fix a Tear in a Jacket Lining: passo 3, imagem 3 %32
    • Take the two ends of the thread and knot them together.
  4. How to Fix a Tear in a Jacket Lining: passo 4, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 4, imagem 2 %32
    • Cut the excess thread off.
  5. How to Fix a Tear in a Jacket Lining: passo 5, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 5, imagem 2 %32 How to Fix a Tear in a Jacket Lining: passo 5, imagem 3 %32
    • Push the needle through the fabric and pull it between the two threads to create a knot.
    • This prevents the thread from sliding through the fabric as you are sewing.
  6. How to Fix a Tear in a Jacket Lining: passo 6, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 6, imagem 2 %32 How to Fix a Tear in a Jacket Lining: passo 6, imagem 3 %32
    • Place one stitch on one side then place another one on the other side of the fabric.
    • Make sure the stitches are parallel and evenly distributed or the seams will not look straight.
    • Repeat this process until you have stitched down the length of the tear.
  7. How to Fix a Tear in a Jacket Lining: passo 7, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 7, imagem 2 %32
    • Pull the thread through.
  8. How to Fix a Tear in a Jacket Lining: passo 8, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 8, imagem 2 %32 How to Fix a Tear in a Jacket Lining: passo 8, imagem 3 %32
    • Close the stitch.
  9. How to Fix a Tear in a Jacket Lining: passo 9, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 9, imagem 2 %32
    • Cut off the excess thread off after securing the stitch.
  10. How to Fix a Tear in a Jacket Lining: passo 10, imagem 1 %32 How to Fix a Tear in a Jacket Lining: passo 10, imagem 2 %32
    • This is the final product.
Conclusão
If you mess up on a stitch, you can always cut and pull it out and start all over again.
4 outras pessoas executaram este guia.
Electra Pyatt
Membro desde: 03/22/21
253 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 89
Ao todo: 7,468
