Ir para o conteúdo principal
How to Fix a Sweater Snag
Hannah Ziebell
Hannah Ziebell e 2 outros colaboradores
Última atualização em 9 de ago de 2025
10 - 20 minutos
Moderado
Introdução
Ir para o passo 1
Fixing a sweater snag is a relatively simple procedure that most people can accomplish with the proper equipment at home. This guide will ensure that you know to how to repair your sweater to increase its longevity while enabling you to get the most wear out of your sweater as well.
O que você precisa
Ferramentas
Exibir mais…
  1. How to Fix a Sweater Snag, How to Fix a Sweater Snag: passo 1, imagem 1 %32 How to Fix a Sweater Snag, How to Fix a Sweater Snag: passo 1, imagem 2 %32
    • Using scissors, cut thread that matches the color of your sweater.
  2. How to Fix a Sweater Snag: passo 2, imagem 1 %32 How to Fix a Sweater Snag: passo 2, imagem 2 %32
    • Pull thread through the needle and tie a knot at the end of the needle.
  3. How to Fix a Sweater Snag: passo 3, imagem 1 %32
    • Lay your sweater out on a smooth surface.
  4. How to Fix a Sweater Snag: passo 4, imagem 1 %32
    • Identify the snag from the inside of your sweater.
  5. How to Fix a Sweater Snag: passo 5, imagem 1 %32 How to Fix a Sweater Snag: passo 5, imagem 2 %32
    • Pull the needle through the sweater at the site of the snag, ensuring that the needle is facing the inside of the sweater.
    • Ensure that you have enough thread to work with.
  6. How to Fix a Sweater Snag: passo 6, imagem 1 %32 How to Fix a Sweater Snag: passo 6, imagem 2 %32
    • Loop the snag around the needle.
    • Begin to pull the needle through the snag to the other side.
  7. How to Fix a Sweater Snag: passo 7, imagem 1 %32 How to Fix a Sweater Snag: passo 7, imagem 2 %32
    • Once again, face the needle towards the inside of the sweater then pull the needle through the site of snag.
  8. How to Fix a Sweater Snag: passo 8, imagem 1 %32 How to Fix a Sweater Snag: passo 8, imagem 2 %32
    • Cut the loose thread.
    • Make sure there is enough thread sticking out from where the snag was.
  9. How to Fix a Sweater Snag: passo 9, imagem 1 %32
    • Identify the site of the snag to ensure steps were followed correctly.
  10. How to Fix a Sweater Snag: passo 10, imagem 1 %32
    • Steam the sweater at the site of the snag to secure the fix in place.
Conclusão
Gear Up For Future Repairs
Shop all
Hannah Ziebell
Membro desde: 02/20/24
181 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 1,049
