Ir para o conteúdo principal
How to Fix a Running Loop on a Knitted Garment
Ben Blischke
Ben Blischke e um outro colaborador
Última atualização em April 12, 2025
30 minutos
Difícil
Guia colaborativo
Introdução
Ir para o passo 1
Knitted garments are cherished for their comfort, but they can develop issues like running loops. We will show you how to repair those loops and keep your jumper looking great. A mending needle is essential for this task, as its fine tip allows you to weave the yarn back into the fabric.
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
  1. How to Fix a Running Loop on a Knitted Garment, Identify the repair area: passo 1, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Identify the repair area: passo 1, imagem 2 %32 How to Fix a Running Loop on a Knitted Garment, Identify the repair area: passo 1, imagem 3 %32
    • Locate the running loop.
    • Note: In this repair, the running loop is located at the edge of the sleeve. This is typically a vertical strand of yarn that has pulled away from the surrounding stitches.
  2. How to Fix a Running Loop on a Knitted Garment, Secure the loop: passo 2, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Secure the loop: passo 2, imagem 2 %32 How to Fix a Running Loop on a Knitted Garment, Secure the loop: passo 2, imagem 3 %32
    • Insert the mending needle through the base of the loop from the inside of the sleeve. Pull it through gently to secure the loop in place.
  3. How to Fix a Running Loop on a Knitted Garment, Catch the vertical stitches: passo 3, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Catch the vertical stitches: passo 3, imagem 2 %32 How to Fix a Running Loop on a Knitted Garment, Catch the vertical stitches: passo 3, imagem 3 %32
    • Carefully weave the mending needle through the vertical stitches and push the loop outwards.
    • Note: This helps to align the loop with the surrounding fabric.
  4. How to Fix a Running Loop on a Knitted Garment, Start hand stitching: passo 4, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Start hand stitching: passo 4, imagem 2 %32 How to Fix a Running Loop on a Knitted Garment, Start hand stitching: passo 4, imagem 3 %32
    • Once the loop has been pulled using the mending needle, change the tool for a normal needle and start hand stitching.
    • Note: In this repair we have chosen a colour thread similar to the pattern on the garment, but we encourage you to be creative and choose a completely different colour or add more contrast, just remember to add your personal touch to your repair!
  5. How to Fix a Running Loop on a Knitted Garment, Continue stitching: passo 5, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Continue stitching: passo 5, imagem 2 %32 How to Fix a Running Loop on a Knitted Garment, Continue stitching: passo 5, imagem 3 %32
    • Following the steps shown in the pictures, continue to stitch replicating the garment's pattern.
  6. How to Fix a Running Loop on a Knitted Garment, Check the stitch: passo 6, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Check the stitch: passo 6, imagem 2 %32 How to Fix a Running Loop on a Knitted Garment, Check the stitch: passo 6, imagem 3 %32
    • In between stitches, check that it is following the right pattern. Test it by gently stretching the sleeve.
  7. How to Fix a Running Loop on a Knitted Garment, Add last stitches: passo 7, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Add last stitches: passo 7, imagem 2 %32 How to Fix a Running Loop on a Knitted Garment, Add last stitches: passo 7, imagem 3 %32
    • Following the steps shown in the pictures, add the last stitches to finish the fix.
  8. How to Fix a Running Loop on a Knitted Garment, Clean the area: passo 8, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Clean the area: passo 8, imagem 2 %32
    • Once you have finished with the last stitches, add a knot at the end and gently pull the thread.
    • Use a pair of scissors to clean the area and cut any loose threads.
  9. How to Fix a Running Loop on a Knitted Garment, Finished and ready!: passo 9, imagem 1 %32 How to Fix a Running Loop on a Knitted Garment, Finished and ready!: passo 9, imagem 2 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro desde: 07/19/23
9.886 Reputação
Autoria de 64 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
24 Membros
Autoria de 164 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 54
Ao todo: 229
