Ir para o conteúdo principal
How to Fix a Razer Naga Trinity Click Button
Haoran Ke
Haoran Ke e um outro colaborador
Última atualização em October 2, 2024
30 - 40 minutos
Moderado
Faltando Passos
Introdução
Ir para o passo 1
Use this guide to fix the broken clicker in your Razer Naga Trinity gaming mouse.
Each mouse has a fixed maximum number of clicks. When the mouse is used for a long time, the clicker of the mouse will have problems. At this time, you will need to manually disassemble the mouse for maintenance.
Make sure you do not use too much force; the parts inside the mouse are sometimes very easy to damage.
This guide is not only applicable to this model,—other mice can also be repaired with this guide, but the internal structure may be different.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: passo 1, imagem 1 %32 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: passo 1, imagem 2 %32 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: passo 1, imagem 3 %32
    • Remove the three pads from the bottom of the mouse.
    • Remove the four screws beneath the pads using a JIS #1 screwdriver.
  2. How to Fix a Razer Naga Trinity Click Button: passo 2, imagem 1 %32 How to Fix a Razer Naga Trinity Click Button: passo 2, imagem 2 %32
    • Press the top of mouse and pull back to disconnect the mouse shell.
    • Pull out the cord that connects the RGB button.
  3. How to Fix a Razer Naga Trinity Click Button: passo 3, imagem 1 %32 How to Fix a Razer Naga Trinity Click Button: passo 3, imagem 2 %32
    • Remove the right shell.
    • Disconnect the cable connecting the left shell to the mouse.
    • Remove the left shell.
  4. How to Fix a Razer Naga Trinity Click Button: passo 4, imagem 1 %32
    • Use a safety pin to unlatch the clicker buttons.
  5. How to Fix a Razer Naga Trinity Click Button: passo 5, imagem 1 %32 How to Fix a Razer Naga Trinity Click Button: passo 5, imagem 2 %32
    • Insert the open safety pin to lift one side latch slightly.
    • Do not open the whole part.
    • Repeat for the other side.
  6. How to Fix a Razer Naga Trinity Click Button: passo 6, imagem 1 %32 How to Fix a Razer Naga Trinity Click Button: passo 6, imagem 2 %32 How to Fix a Razer Naga Trinity Click Button: passo 6, imagem 3 %32
    • Remove the clicker and white pin.
    • Gently press the middle part of the copper sheet until it unhooks itself.
    • Pull the bended part of the copper sheet back.
  7. How to Fix a Razer Naga Trinity Click Button: passo 7, imagem 1 %32
    • Reassemble the copper sheet with the white pin seated properly.
    • Push the spring down into its place using a spudger.
    • You will hear a click sound if you successfully assemble it.
Conclusão
4 outras pessoas executaram este guia.
Haoran Ke
Membro desde: 01/13/22
283 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
On the latest version of the mouse, the clicker button can no longer be opened...
Jérémie PLAYOUT - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 43
Últimos 30 dias: 243
Ao todo: 11,874
