Ir para o conteúdo principal
How to Fix a Rattling Door
Sara Novell
Sara Novell e 4 outros colaboradores
Última atualização em February 19, 2016
10 minutos
Fácil
Introdução
Ir para o passo 1
Sometimes doors don’t fit well into their frames. That’s due to the spring loaded lock not fitting well into the strike plate of the door. This can get annoying when wind blows through the house and rattles the door. The problem probably originates from the metal tab on the strike plate being bent away from the door.
O que você precisa
Ferramentas
Exibir mais…
  1. How to Fix a Rattling Door, How to Fix a Rattling Door: passo 1, imagem 1 %32 How to Fix a Rattling Door, How to Fix a Rattling Door: passo 1, imagem 2 %32 How to Fix a Rattling Door, How to Fix a Rattling Door: passo 1, imagem 3 %32
    • Remove the strike plate on the door by unscrewing the screws that attach it to the door frame.
    • The type of screwdriver you need depends on the type of screws that hold your strike plate in your door.
  2. How to Fix a Rattling Door: passo 2, imagem 1 %32 How to Fix a Rattling Door: passo 2, imagem 2 %32
    • Take the strike plate and put it in your hand. Using the pliers in your other hand, bend the metal tab toward the flat side of the strike plate.
  3. How to Fix a Rattling Door: passo 3, imagem 1 %32 How to Fix a Rattling Door: passo 3, imagem 2 %32
    • Place the strike plate back on the door frame and tighten the screws.
Conclusão
Close your door and shake it back and forth to see if it is still loose. Repeat the guide steps as necessary.
Sara Novell
Membro desde: 04/08/15
209 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 30-4, Green Spring 2015 Membro de Cal Poly, Team 30-4, Green Spring 2015
CPSU-GREEN-S15S30G4
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 37
Ao todo: 40,111
