Ir para o conteúdo principal
How to Fix a Papasan Chair Base
Cassidy Calcutt
Cassidy Calcutt e um outro colaborador
Última atualização em 16 de jan de 2023
30 - 45 minutos
Fácil
Introdução
Ir para o passo 1
These steps encompass most of the breaks you might encounter in a wooden papasan chair base. It is a quick and simple set of repairs that will allow you to enjoy your papasan chair for many years to come.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: passo 1, imagem 1 %32 How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: passo 1, imagem 2 %32
    • Remove and save rattan from broken sections.
  2. How to Fix a Papasan Chair Base: passo 2, imagem 1 %32
    • Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
  3. How to Fix a Papasan Chair Base: passo 3, imagem 1 %32 How to Fix a Papasan Chair Base: passo 3, imagem 2 %32
    • Glue the split wood pieces together, clamp, and let them dry.
  4. How to Fix a Papasan Chair Base: passo 4, imagem 1 %32
    • Nail the thin decorative wood pieces to the larger sections of the frame.
  5. How to Fix a Papasan Chair Base: passo 5, imagem 1 %32
    • Screw the circular base and upper to the vertical supports that have become disconnected.
    What is the size of the screw?
    Lourdes Diaz - Responder
    Or what kind (spec) of screw do I need for this part?
  6. How to Fix a Papasan Chair Base: passo 6, imagem 1 %32
    • Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
  7. How to Fix a Papasan Chair Base: passo 7, imagem 1 %32 How to Fix a Papasan Chair Base: passo 7, imagem 2 %32
    • Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
Conclusão
Following these steps will restore your papasan chair to working order.
6 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
3Comentários do guia
What screw you used? Screw dimensions?
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
Carrmone Bears - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 30
Últimos 30 dias: 141
Ao todo: 20,846
