Ir para o conteúdo principal
How to Fix a Misaligned Desk Drawer
Dante Mazzanti
Dante Mazzanti e 4 outros colaboradores
Última atualização em February 19, 2016
15 minutos
Fácil
Introdução
Ir para o passo 1
Do you have a desk drawer that just won't line up correctly? Follow the simple steps in this guide to correctly line up your drawer and make your life just a little bit easier.
The specific screwdrivers and screws used in this guide may not be the same used in other desk drawers. If you have any questions I recommend going to your local hardware store.
  1. How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: passo 1, imagem 1 %32 How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: passo 1, imagem 2 %32
    • Start by pulling the drawer out and detaching it from the hardware mounted to the desk.
    • To do this you need to push the black plastic lever up in order to disengage the drawer's hardware from the desk's hardware.
  2. How to Fix a Misaligned Desk Drawer: passo 2, imagem 1 %32 How to Fix a Misaligned Desk Drawer: passo 2, imagem 2 %32
    • In this case the hardware on the left side of the drawer is not functioning properly due to a bent metal piece.
    • Using the flat head screwdriver you can push the metal down around each ball bearing in order to allow the drawer to slide back and forth.
  3. How to Fix a Misaligned Desk Drawer: passo 3, imagem 1 %32 How to Fix a Misaligned Desk Drawer: passo 3, imagem 2 %32
    • The hardware attached to the drawer is also not functioning properly due to missing screws.
    • Use replacement screws to properly attach the hardware to the drawer and to allow it to support the drawer's weight.
    • Take a screw from the drawer to your local hardware store for help finding matching screws.
  4. How to Fix a Misaligned Desk Drawer: passo 4, imagem 1 %32
    • After attaching the hardware slide the drawer's piece into its counterpart on the desk.
    • It can be awkward to maneuver the drawer in alone. You may need to get some help for this step.
  5. How to Fix a Misaligned Desk Drawer: passo 5, imagem 1 %32
    • Enjoy your fully functioning drawer!
Conclusão
Dante Mazzanti
Membro desde: 02/23/15
598 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 16,366
