Ir para o conteúdo principal
How to Fix a Hole in a Pant Pocket
O que você precisa
  1. How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: passo 1, imagem 1 %32 How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: passo 1, imagem 2 %32
    • Flip the pocket inside out.
  2. How to Fix a Hole in a Pant Pocket: passo 2, imagem 1 %32 How to Fix a Hole in a Pant Pocket: passo 2, imagem 2 %32
    • Carefully align the ripped part of the pocket together.
  3. How to Fix a Hole in a Pant Pocket: passo 3, imagem 1 %32 How to Fix a Hole in a Pant Pocket: passo 3, imagem 2 %32 How to Fix a Hole in a Pant Pocket: passo 3, imagem 3 %32
    • Put a sewing pin into a stable piece of fabric to make a hole.
    • Carefully remove the pins.
  4. How to Fix a Hole in a Pant Pocket: passo 5, imagem 1 %32 How to Fix a Hole in a Pant Pocket: passo 5, imagem 2 %32 How to Fix a Hole in a Pant Pocket: passo 5, imagem 3 %32
    • Carefully insert the a threaded sewing needle into the hole you created at one end of the tear.
    • Sew along the length of the tear, joining the two pieces of fabric together.
    • Be very careful when using needle as the point can be very sharp and lead to injury.
  5. How to Fix a Hole in a Pant Pocket: passo 6, imagem 1 %32 How to Fix a Hole in a Pant Pocket: passo 6, imagem 2 %32
    • Sew around the ending part a couple times to prevent it from loosen again.
  6. How to Fix a Hole in a Pant Pocket: passo 7, imagem 1 %32
    • Tie a few knots on both ends of the closed tear to ensure the stitching doesn't come loose.
    • Carefully cut the remaining thread.
    • Be very careful while cutting the thread to avoid cutting some part of the material also.
Conclusão
Dolapo Ajose
Membro desde: 09/20/21
220 Reputação
Autoria de 1 guia
Equipe
Um comentário
I found a good reference video for this guide: https://youtube.com/watch?v=LJ5y4mLVbY0
5moufl - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 48
Últimos 30 dias: 194
Duração total: 2,849
