Ir para o conteúdo principal
How to Fix a Dry Printer Cartridge
Hariom Godhani
Hariom Godhani e um outro colaborador
Última atualização em 2 de mai de 2024
10 - 20 minutos
Fácil
Introdução
Ir para o passo 1
Not using a printer for a long period of time can cause the ink inside it to dry. When we can’t use the dried ink cartridge, most of us get rid of it and buy a new cartridge, which contributes to the increasing e-waste. Instead of discarding a dry cartridge, this guide will help you to fix it in a few easy steps with a couple of things needed which can be found right in your house.
O que você precisa
Ferramentas
  1. How to Fix a Dry Printer Cartridge, Removing the Cartridge: passo 1, imagem 1 %32 How to Fix a Dry Printer Cartridge, Removing the Cartridge: passo 1, imagem 2 %32 How to Fix a Dry Printer Cartridge, Removing the Cartridge: passo 1, imagem 3 %32
    • Open the top case of your printer.
    • Carefully remove the dried cartridge by lifting the flap in the bottom right section of the printer.
  2. How to Fix a Dry Printer Cartridge, Applying Hand Sanitizer: passo 2, imagem 1 %32 How to Fix a Dry Printer Cartridge, Applying Hand Sanitizer: passo 2, imagem 2 %32
    • Place the cartridge on a clean surface and apply a few drops of alcohol-based hand sanitizer to the ink nozzle.
    • It's best to use an unscented hand sanitizer, as some scents or colors in the hand sanitizer may affect your ink cartridge's performance.
    • Gently rub your finger on the ink nozzle once or twice.
    • Let the sanitizer seep in for a few minutes.
    • While you wait, fill a bowl halfway with warm tap water.
  3. How to Fix a Dry Printer Cartridge, Wipe it out: passo 3, imagem 1 %32 How to Fix a Dry Printer Cartridge, Wipe it out: passo 3, imagem 2 %32
    • Wipe out the ink nozzle where you applied the sanitizer with a clean cloth or paper towel.
  4. How to Fix a Dry Printer Cartridge, Warm Water Bath: passo 4, imagem 1 %32 How to Fix a Dry Printer Cartridge, Warm Water Bath: passo 4, imagem 2 %32 How to Fix a Dry Printer Cartridge, Warm Water Bath: passo 4, imagem 3 %32
    • Place the nozzle side of the cartridge into a bowl filled with warm water.
    • Do not completely submerge the cartridge inside the water, just half of it.
    • Wait for 5-10 mins or until you see ink leaking out into the water.
    • Once you see ink leaking out, remove the cartridge from the water carefully.
    • It may be a good idea to keep a bit of paper towel or a rag handy to catch any drips from the ink cart.
  5. How to Fix a Dry Printer Cartridge, Dry it Completely: passo 5, imagem 1 %32
    • After removing it from the water, completely clean the cartridge with a soft cloth or a paper towel and dry it out.
    • DO NOT put a wet cartridge inside the printer, else it can damage it.
  6. How to Fix a Dry Printer Cartridge, Double Check: passo 6, imagem 1 %32
    • To make sure the cartridge is fully working now, take a piece of paper and rub the ink nozzle over it.
    • When you see an ink line on the paper, that means you are good to go.
  7. How to Fix a Dry Printer Cartridge, Fixing it Back: passo 7, imagem 1 %32
    • Once the body of the cartridge has completely dried, place it back into the slot in the printer.
    I followed your instructions and it worked great on my dried up cartridge. It wasn't a long procedure at all and it saved me another trip to the store. Thank you.
    Janet Gates - Responder
    Worked great on the black cartridge, but the color one is only printing yellow..go figure... great guide anyway
    Jacopo Grassi - Responder
    How long does it take to completely dry out after all the steps ??
    Mom - Responder
    Yay I fixed something, thank you!
    Thomas ad - Responder
Conclusão
13 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Hariom Godhani
Membro desde: 10/01/21
502 Reputação
Autoria de 1 guia
8Comentários do guia
Thank you. This worked for me.
Thomas Grace - Responder
This actually worked . Did just as you instructed , didn't see ink in the hot water but after a few minutes I dried the cartridges off and had ink on the paper towel . Worked great ,Thanks Hariom .
Tim - Responder
Tried this with HP 60 black and tri-colour cartridges, which were both brand new, sealed cartridges, but were probably sitting in the box since ~2008. It did manage to loosen the ink up enough that if I ran the nozzle along a damp coffee filter, it would leave a solid black line, or in the case of the colour cartridge, a line of 3 stripes: cyan, yellow, then magenta. Unfortunately, the moment I dry them off and pop them back in the printer, nothing happens. I did manage to get the faded mostly cyan top third of a test page once, but that was it. Repeated the process more thoroughly, and got a more consistent output of ink on the filter, but the result after that was nothing but blank sheets.
Not really sure what to do beyond this, because I could probably just pick up a new printer for the price of these cartridges. This would probably work well for newer cartridges that were printing fine, but then were just left idle for a few months too long between prints.
Jordan “gordo” Zanatta - Responder
At least you tried it and you know what to do if the cartridges aren't left for a lessor time.
DEAN -
I agree completely. I purchased a printer from Walmart just for a few printing needs and just in case, but after one use it didn't work. The printer was cheaper than the price of 1 of the cartridges. I don't often need a printer as most things are done online now. But, it's good to have one. No use if it's junk. 🤷🏼‍♀️
Toughcookie122 -
This looks hopeful. You can use a quick and dirty "vacuum chamber" (costs less than 5 bucks):
https://www.instructables.com/How-to-Rev...
Daire O Broin - Responder
Thank you. It is a good tip.It works well.
abir banerjee - Responder
Comentar
Visualizações:
Últimas 24 horas: 30
Últimos 7 dias: 223
Últimos 30 dias: 898
Ao todo: 53,620
