How to Fix a Delta 5-Function Showerhead Model 75554
Introdução
Ir para o passo 1This repair guide is a step-by-step of instructions to ensure you are using the correct materials and tools to fix your Delta 5-Function Showerhead Model 75554. This showerhead has a major leak in it, which I have found that it is where is screws onto the shower pipe itself. The reasoning behind this guide is that it gets very slippery when I walk into my shower because of how bad, and often the head is leaking.
O que você precisa
Ferramentas
Exibir mais…
Unscrew the head of the shower from the pipe with a pipe wrench.
Uma outra pessoa concluiu este guia.
