Ir para o conteúdo principal
How to Fix a Crack in a Hollow Wood Door
Lea Thomas
Lea Thomas e um outro colaborador
Última atualização em December 28, 2022
30 minutos - 1 hora
Moderado
Introdução
Ir para o passo 1
This Fast Fix can be used to patch a crack in any hollow wood door. The materials that will need to be purchased include body/wood filler, sandpaper/sanding sponge, paint, putty knife, and a paint brush. To prevent any hazards, gloves and a face mask are recommended. Overall, this Fast fix should take no longer than an hour to complete and should not cost over $10 when purchasing the required materials.
  1. How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: passo 1, imagem 1 %32 How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: passo 1, imagem 2 %32
    • Clean and dust the affected area with a paper towel, rag, or brush.
  2. How to Fix a Crack in a Hollow Wood Door: passo 2, imagem 1 %32
    • Sand the affected area with a 60/80 grit sanding sponge.
    • Any type of sand paper or sanding sponge will work on wood surfaces.
    • It is recommended to place newspaper under the door to keep the sand/dust contained.
  3. How to Fix a Crack in a Hollow Wood Door: passo 3, imagem 1 %32
    • Remove any sand/dust with a paper towel.
    • It is recommend to use gloves to prevent any minor splinters.
    • It is also recommended to use a face mask to prevent inhaling any dust/sand.
  4. How to Fix a Crack in a Hollow Wood Door: passo 4, imagem 1 %32
    • Use putty knife to apply body filler until an even layer is formed.
    • Start with a small amount and then add more if needed.
    • A smaller putty knife allows for easier application in creases and folds.
  5. How to Fix a Crack in a Hollow Wood Door: passo 5, imagem 1 %32
    • Remove any excess body filler with putty knife
    • Its okay if the surface is uneven, you will use sandpaper to smooth the surface in a later step.
  6. How to Fix a Crack in a Hollow Wood Door: passo 6, imagem 1 %32
    • Allow to dry (or use a blow dryer for lesser wait time).
    • More expensive brands of body filler will dry faster.
  7. How to Fix a Crack in a Hollow Wood Door: passo 7, imagem 1 %32 How to Fix a Crack in a Hollow Wood Door: passo 7, imagem 2 %32
    • Gently sand the surface.
    • Gloves and a face mask are highly recommended but not required for this step.
    • Newspaper is also recommended to contain any sand/dust.
    • Reapply body filler, allow to dry, and re-sand if surface remains uneven.
  8. How to Fix a Crack in a Hollow Wood Door: passo 8, imagem 1 %32
    • Use a similar toned paint to paint the area if any discoloration exists.
    • Wood paint is ideal for wood doors.
  9. How to Fix a Crack in a Hollow Wood Door: passo 9, imagem 1 %32
    • Allow to dry.
    • Your door should now look neutral and clean.
    • A blow dryer is recommended for faster drying.
Conclusão
3 outras pessoas executaram este guia.
Lea Thomas
Membro desde: 01/20/19
250 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 119
Últimos 30 dias: 589
Ao todo: 145,580
