Ir para o conteúdo principal
How to Fix a Carpet Dent
Abigail  Gaines
Abigail Gaines e um outro colaborador
Última atualização em June 21, 2021
10 minutos
Muito fácil
Introdução
Ir para o passo 1
In this guide I will document the process of fixing those pesky indentations in your carpet caused by pressure from heavy furniture. This process is simple, easy, and fast! If you do not want people seeing your carpet dent and need a fast fix, then this is the right guide for you! You will start by raking the carpet to separate the fibers, next you will submerge your white towel in the cold water, and dampen your carpet while pushing down. Next, you will take your steamer or iron and put heat on top of white towel and effected area, lift up and see your results!
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Fix a Carpet Dent, How to Fix a Carpet Dent: passo 1, imagem 1 %32
    • First decide what carpet dent you would like to fix.
  2. How to Fix a Carpet Dent: passo 2, imagem 1 %32
    • Rake the carpet with the fork to break up the fibers in the carpet.
  3. How to Fix a Carpet Dent: passo 3, imagem 1 %32
    • Submerge your white towel into the bowl of cold water.
  4. How to Fix a Carpet Dent: passo 4, imagem 1 %32
    • Place the damp towel over the carpet dent and push down.
  5. How to Fix a Carpet Dent: passo 5, imagem 1 %32
    • Put a steamer or clothes iron on top of the white towel so the heat from the steam can lift the carpet fibers.
  6. How to Fix a Carpet Dent: passo 6, imagem 1 %32
    • Lift up your towel and see your brand new carpet!
    • The carpet may take an hour or two to fully dry, so be careful not to step on the wet area right away!
Conclusão
In conclusion, this is an incredibly easy process which takes very little time and effort. Very helpful if you have just rearranged a room and do not want noticeable carpet dents.
Abigail Gaines
Membro desde: 02/17/21
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 462
