How to Fix a Broken Seam on Pants
Introdução
Vá para o passo 1A broken seam on your favorite pants can prevent you from using them, but did you know there is a simple way to fix the problem? Whether it’s a small tear or a larger unraveling, knowing how to repair it can help you keep your wardrobe looking great. We will teach you the step-by-step solution on how to get those pants back in shape!
O que você precisa
Ferramentas
Exibir mais…
Identify the part of the pants that needs repairing and gather all the necessary tools.
Use sewing pines or needles to pin the seam area and hold it together for the next step.
Once the area has been fixed with the pins, use a seam ripper to remove the old threads.
If there are still any remaining loose threads, use a pair scissors to cut them.
Use a sewing machine to stitch the marked area.
Finish up the stitch by cutting any loose threads with a pair of scissors.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
