Ir para o conteúdo principal
How to Fix a Broken Seam on Pants
Ben Blischke
Ben Blischke e um outro colaborador
Última atualização em January 8, 2025
20 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
A broken seam on your favorite pants can prevent you from using them, but did you know there is a simple way to fix the problem? Whether it’s a small tear or a larger unraveling, knowing how to repair it can help you keep your wardrobe looking great. We will teach you the step-by-step solution on how to get those pants back in shape!
  1. How to Fix a Broken Seam on Pants, Locate the repair area: passo 1, imagem 1 %32 How to Fix a Broken Seam on Pants, Locate the repair area: passo 1, imagem 2 %32 How to Fix a Broken Seam on Pants, Locate the repair area: passo 1, imagem 3 %32
    • Identify the part of the pants that needs repairing and gather all the necessary tools.
  2. How to Fix a Broken Seam on Pants, Pin the area: passo 2, imagem 1 %32 How to Fix a Broken Seam on Pants, Pin the area: passo 2, imagem 2 %32 How to Fix a Broken Seam on Pants, Pin the area: passo 2, imagem 3 %32
    • Use sewing pines or needles to pin the seam area and hold it together for the next step.
  3. How to Fix a Broken Seam on Pants, Clean the area: passo 3, imagem 1 %32 How to Fix a Broken Seam on Pants, Clean the area: passo 3, imagem 2 %32
    • Once the area has been fixed with the pins, use a seam ripper to remove the old threads.
    • If there are still any remaining loose threads, use a pair scissors to cut them.
  4. How to Fix a Broken Seam on Pants, Start stitching: passo 4, imagem 1 %32 How to Fix a Broken Seam on Pants, Start stitching: passo 4, imagem 2 %32 How to Fix a Broken Seam on Pants, Start stitching: passo 4, imagem 3 %32
    • Use a sewing machine to stitch the marked area.
    • Finish up the stitch by cutting any loose threads with a pair of scissors.
  5. How to Fix a Broken Seam on Pants, Finished and ready!: passo 5, imagem 1 %32 How to Fix a Broken Seam on Pants, Finished and ready!: passo 5, imagem 2 %32 How to Fix a Broken Seam on Pants, Finished and ready!: passo 5, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
22 Membros
Autoria de 159 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 42
Ao todo: 156
