Ir para o conteúdo principal
How to Fix a Broken Plastic Figurine
Jackson Smith
Jackson Smith e 3 outros colaboradores
Última atualização em December 23, 2024
10 minutos
Fácil
Collectable figurines can develop defects or suffer damage over time. To address this issue, we have come up with a quick and easy solution to repairing a broken plastic figurine. Using a hot glue gun as a heat source, without the use of glue, you can restore your collectable figurines back to its pristine condition.
  1. How to Fix a Broken Plastic Figurine, How to Fix a Broken Plastic Figurine: passo 1, imagem 1 %32 How to Fix a Broken Plastic Figurine, How to Fix a Broken Plastic Figurine: passo 1, imagem 2 %32
    • Wipe down the figurine carefully with an alcohol wipe, focusing on the broken areas.
  2. How to Fix a Broken Plastic Figurine: passo 2, imagem 1 %32 How to Fix a Broken Plastic Figurine: passo 2, imagem 2 %32 How to Fix a Broken Plastic Figurine: passo 2, imagem 3 %32
    • Plug in the hot glue gun and let it heat up.
    • Do not directly touch the tip of the hot glue gun.
    • Straighten out the paperclip.
    • Place the paperclip in the tip of the hot glue gun in order to heat the metal.
    • Allow the paperclip to heat up for 5 minutes.
  3. How to Fix a Broken Plastic Figurine: passo 3, imagem 1 %32
    • Remove the paperclip from the glue gun.
    • Use the heated paperclip to scrape away excess material from one part of the figurine.
  4. How to Fix a Broken Plastic Figurine: passo 4, imagem 1 %32
    • Firmly press the glue gun's heated tip into the other part of the figurine to melt the surrounding plastic for smoother placement.
  5. How to Fix a Broken Plastic Figurine: passo 5, imagem 1 %32 How to Fix a Broken Plastic Figurine: passo 5, imagem 2 %32
    • Align the broken pieces together carefully.
    • Press the two pieces together.
    • Hold together tightly for a minute to bond the pieces.
  6. How to Fix a Broken Plastic Figurine: passo 6, imagem 1 %32 How to Fix a Broken Plastic Figurine: passo 6, imagem 2 %32 How to Fix a Broken Plastic Figurine: passo 6, imagem 3 %32
    • Apply tape to keep the pieces together.
    • Let it sit for 1 hour.
  7. How to Fix a Broken Plastic Figurine: passo 7, imagem 1 %32 How to Fix a Broken Plastic Figurine: passo 7, imagem 2 %32
    • Remove the tape top-down.
    • You're finished!
Linha de Chegada
Uma outra pessoa concluiu este guia.
Jackson Smith
Membro desde: 11/05/24
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-2, Vidal-Chiesa Fall 2024 Membro de UC Davis, Team 2-2, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G2
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 84
