How to Fix a Broken LED in a Shower Head
Introdução
Ir para o passo 1When you start noticing low pressure in your shower and the LED light goes out, there are several reasons. One of the most common ones is that the shower head is clogged with mineral deposits. We will show you how helpful LED shower heads are and how to restore them to brand new! Extended periods of time when the shower head doesn't get cleaned can lead to the water turbine's ineffectiveness in picking up electricity to keep the LED going. This guide will show you how to clean and restore a shower head and LED.
O que você precisa
Ferramentas
Exibir mais…
Fit a 6-inch adjustable wrench to the shower head bracket.
Move the wrench clockwise to loosen the shower head from the bracket.
Test your shower head to see if mineral deposits prevent good water pressure and create energy for the LED. If this issue persists, repeat this process and shoot the distilled vinegar inside the shower head.
