Ir para o conteúdo principal
How to Fix a Broken Air-Dry Clay Figurine
Rhea Matsumoto
Rhea Matsumoto e 3 outros colaboradores
Última atualização em December 23, 2024
1 - 3 dias
Moderada
Air-dry clay figurines are fragile and can be easily broken through accidental falls and careless holding. This guide aims to instruct crafters on how to fix broken air-dry clay ornaments. Through the guide steps, you will learn how to put clay fractures back together and restore to its original state.
Caution: This guide uses a hot glue gun and blow dryer (optional). Please be careful when handling the equipment and unplug them when you finish the specific steps.
  1. How to Fix a Broken Air-Dry Clay Figurine, How to Fix a Broken Air-Dry Clay Figurine: passo 1, imagem 1 %32
    • Collect the air-dry clay fractures.
  2. How to Fix a Broken Air-Dry Clay Figurine: passo 2, imagem 1 %32
    • Brush out the clay debris from the clay piece's surface.
  3. How to Fix a Broken Air-Dry Clay Figurine: passo 3, imagem 1 %32 How to Fix a Broken Air-Dry Clay Figurine: passo 3, imagem 2 %32
    • Preheat the hot glue gun.
    • Apply the hot glue onto the cracked surface.
    • Try to work quickly on this step. The hot glue dries and hardens very fast.
  4. How to Fix a Broken Air-Dry Clay Figurine: passo 4, imagem 1 %32
    • Attach the corresponding fractured pieces. Press and hold the clay for at least 10 seconds to allow the clay to set.
    • Strip away excess hot glue to avoid potential additional damage.
    • If there are multiple cracks, repair one fractured area at a time to prevent hassle.
  5. How to Fix a Broken Air-Dry Clay Figurine: passo 5, imagem 1 %32 How to Fix a Broken Air-Dry Clay Figurine: passo 5, imagem 2 %32
    • Place a small amount of air-dry clay on the paint palette.
    • Apply some water to the air-dry clay and mix them with a brush or your fingers.
    • Add water gradually to avoid over-moisturizing the paste.
    • Continue mixing until the paste reaches a jam-like consistency.
  6. How to Fix a Broken Air-Dry Clay Figurine: passo 6, imagem 1 %32 How to Fix a Broken Air-Dry Clay Figurine: passo 6, imagem 2 %32 How to Fix a Broken Air-Dry Clay Figurine: passo 6, imagem 3 %32
    • Grab some clay paste and apply it along the cracked surface.
    • Smooth out the paste with your fingers or a brush.
  7. How to Fix a Broken Air-Dry Clay Figurine: passo 7, imagem 1 %32
    • Choose one of the following steps that fits the best:
    • Wait for the air-dry clay to fully dry and harden. This step takes at least 2 days.
    • Use a blow dryer to speed up the drying process. This step is optional, but the dry time can be shortened to 15 minutes.
    • Rushing to the next step without allowing the ornament to fully dry may result in additional damages.
  8. How to Fix a Broken Air-Dry Clay Figurine: passo 8, imagem 1 %32
    • Polish the repaired surface using sandpaper.
  9. How to Fix a Broken Air-Dry Clay Figurine: passo 9, imagem 1 %32 How to Fix a Broken Air-Dry Clay Figurine: passo 9, imagem 2 %32
    • Paint the dried clay with the corresponding colors.
  10. How to Fix a Broken Air-Dry Clay Figurine: passo 10, imagem 1 %32 How to Fix a Broken Air-Dry Clay Figurine: passo 10, imagem 2 %32
    • Paint the repaired surface with glossy or matte varnish.
    • Wait for the varnish to be fully dried. This takes 1 day.
    • Do not use a blow dryer for this step. Varnish cannot be dried through hot air.
  11. How to Fix a Broken Air-Dry Clay Figurine: passo 11, imagem 1 %32 How to Fix a Broken Air-Dry Clay Figurine: passo 11, imagem 2 %32
    • The broken air-dry clay craft ornament is now fixed!
Linha de Chegada
Rhea Matsumoto
Membro desde: 11/05/24
245 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-5, Vidal-Chiesa Fall 2024 Membro de UC Davis, Team 3-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G5
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 31
Duração total: 165
