How to Fix Subwoofer Amplifiers
Introdução
Ir para o passo 1This is how you get better connection for your amplifier, which can be the cause of it not working. The main issues that happen when your subwoofers are not working includes improper wire connection, blown fuse, or shortage in wiring.
O que você precisa
Ferramentas
Exibir mais…
Disconnect the black (negative) cable from the battery to disable the electrical connection.
Disconnect the red (positive) cable from the battery to disable the electrical connection.
Uma outra pessoa concluiu este guia.
