How to Fix Plastic Chair Cracks
Introdução
Ir para o passo 1This guide will show you how to repair a crack in a generic plastic chair. The cracks this guide specifically addresses include partial cracks on the chair body/legs and full cracks on the chair spindle.
This guide focuses on how to repair a crack on the chair spindle. It involves making a new seal for the crack using super glue and baking soda and sanding it down to bring the broken area back to its original look.
Warning: Work in an area with good ventilation. Isopropyl alcohol is flammable. Additionally, wear protective clothing to avoid getting super glue on your clothes or skin.
O que você precisa
Ferramentas
Exibir mais…
Lay the broken chair such that the crack is parallel to the floor.
After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
Y para una pata de silla Rota que hacer ?
Existe remedio para la pata de una silla de plástico rota .?
The crack has been repaired!
13 outras pessoas executaram este guia.
3Comentários do guia
Do you push the baking soda down into the glue (or into the crack), or just spread evenly on the surface?
What glue did you use?
