Ir para o conteúdo principal
How to Fix Melted or Lumpy EOS Lip Balm
Kate Hubbell
Kate Hubbell e 4 outros colaboradores
Última atualização em June 14, 2016
10 minutos
Muito fácil
Introdução
Ir para o passo 1
This is a very simple process for repairing a melted or broken EOS lip balm that will require no more than five minutes of work, with another 10 minutes of allowing the finished product to cool.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Fix Melted or Lumpy EOS Lip Balm, How to Fix Melted or Lumpy EOS Lip Balm: passo 1, imagem 1 %32 How to Fix Melted or Lumpy EOS Lip Balm, How to Fix Melted or Lumpy EOS Lip Balm: passo 1, imagem 2 %32
    • To begin, open the lip-balm and use the knife to separate the center piece which holds the lip-balm in place from the bottom portion of the container.
    • Knives are sharp, and you need to apply some force to split the container from the grate. It is easier to wedge the knife by the little, square notch that would usually lock the EOS.
  2. How to Fix Melted or Lumpy EOS Lip Balm: passo 2, imagem 1 %32 How to Fix Melted or Lumpy EOS Lip Balm: passo 2, imagem 2 %32
    • Once they’ve been separated, remove the lip-balm from the center grate and place all pieces into the small microwavable bowl.
  3. How to Fix Melted or Lumpy EOS Lip Balm: passo 3, imagem 1 %32 How to Fix Melted or Lumpy EOS Lip Balm: passo 3, imagem 2 %32
    • Stirring every 10-15 seconds, microwave the bowl of balm until it reaches a liquid state.
    • Be sure to stir every 10-15 seconds. Balm that is left too long in the microwave will become dry and burned.
  4. How to Fix Melted or Lumpy EOS Lip Balm: passo 4, imagem 1 %32
    • Immediately after removing the balm from the microwave, snap the middle grate into place on the top of the container this time
  5. How to Fix Melted or Lumpy EOS Lip Balm: passo 5, imagem 1 %32
    • Pour the melted lip-balm through the grate and into the lid of the container in order to allow the balm to take shape of the container and to settle into the grate.
  6. How to Fix Melted or Lumpy EOS Lip Balm: passo 6, imagem 1 %32
    • Place the open container in the fridge or freezer for approximately 10 minutes, or until the balm is hardened.
  7. How to Fix Melted or Lumpy EOS Lip Balm: passo 7, imagem 1 %32
    • Once settled, remove from freezer and snap the bottom of the container firmly to put the pieces back together.
  8. How to Fix Melted or Lumpy EOS Lip Balm: passo 8, imagem 1 %32
    • Twist open the container as usual; your lip-balm should be good as new!
Conclusão
That's it! Enjoy your nice, smooth EOS.
8 outras pessoas executaram este guia.
Kate Hubbell
Membro desde: 01/19/16
290 Reputação
Autoria de 1 guia
Equipe
12Comentários do guia
WORKS GREAT! They don't sell these by me and I had picked up one in NYC last time I was there and fell in love with them. So, I ordered a 5 pack from Amazon and 3 of them came melted into the cap. I did exactly as the instructions said, and PERFECT! Thank you thank you thank you!!!
bobafett40 - Responder
Thank you soo much for posting this it actually worked thank you!!!
BOOYAKASHAKA - Responder
This was amazing it worked so well I wasn't sure it was going to work but then it came out looking brand spanking new!!!
Rolanda Williams - Responder
Does this technique work for the eos crystal?
Stacey Whittington - Responder
Does this technique work for smoothing out an eos crystal?
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 51,606
